05-18-2015, 09:37 PM
Looking for any Thomas wiring diagrams
Any help is appreciated. Bus is a 1992 Thomas school bus. Wiring has been modified by others. Thanks, Frank frank.id.crownatgmail.com
05-18-2015, 10:14 PM
If you need the Vandalock wiring I have a copy of that. I've posted it before too.
~Pamela
05-18-2015, 10:20 PM
Chassis: B3800 Short bus
This is from my 1997 Thomas/International. You may or may not get something useful out of it...
05-22-2015, 08:32 AM
Chassis: Saf-T-Liner MVP ER
Engine: CAT 3126b Rotella-Chugger
PM me, I have diagrams for older ones too.
05-22-2015, 01:37 PM
Engine: Detroit 8.2
I have the wiring diagram for an 86 if it will help
02-29-2016, 08:24 PM
Coachwork: Chevrolet
Engine: 8.2L Detroit Diesel
Rated Cap: 35p
just purchased an 88... would love to see them..
Check out the build for The Eldon: https://eldonthebus.tumblr.com/
03-01-2016, 02:02 AM
Year: 1978
Chassis: Lifeguard
Engine: 366 Chevy
Me, too.
Me, too.
06-19-2016, 02:39 PM
Those would be super helpful, have an 87 .. thanks
06-20-2016, 12:11 AM
Year: 90
Chassis: safe-t-liner
Engine: cat re
Rated Cap: 79
I would also like to see them, I have a 90
02-24-2018, 10:44 PM
Chassis: Ford E-350
Engine: 6.9L Diesel
I know you posted almost three years ago but I have an 86 & Diagrams would be lovely. I sent you a PM as well.
1986 Ford E350/Thomas Minotour
PlantDrive TTVTM SVO conversion
02-25-2018, 08:51 PM
Chassis: Saf-T-Liner ER
Engine: Cummins ISC 8.3 Allison MD3060
I have a 1999 Thomas Built bus ER service manual, PM me and I will kindly pay it forward and share.
James
03-10-2018, 06:31 PM
Chassis: Ford E-350
Engine: 6.9L Diesel
I found some wiring diagrams for 1997 & older Minotours online.
http://shop.pwt.ca/Electrical%20Manu...electrical.pdf
The way it's organized online is a little out of the ordinary. Rather than having a downloadable master PDF file, or HTML pages with links to individual PDF files for the different components, it's a table of contents PDF file that links to other PDF files. So if you want to save them to your hard drive for later reference, you need to click on the links in the main table of contents, then save the resulting PDF file from each of the links.
Hope this helps.
H.
09-10-2018, 09:58 AM
Chassis: Ford E-350
Engine: Ford 351 Windsor
Rated Cap: 16
Is there a wiring diagram for an '88 Minotour available? It would probably be better to post them here rather than sharing them privately.
09-10-2018, 10:15 AM
Chassis: MVP
Engine: 8.3L Cummins Turbo
Thomas electrical
I've used this as a reference:
it's pretty complete for the Thomas MVP series.
https://drive.google.com/drive/folde...1lTandWYmFRaVk
11-10-2018, 08:00 PM
Chassis: MVP RE
James I have a Thomas 5.9 ER that I need so service info for. Currently I'm in a no start situation with good batteries. Not sure if the wiring circuit is similar. Please PM me and I can go into detail with my request. Thanks
Bud
06-09-2019, 08:21 PM
Chassis: Ford B600
Hi Jolly Roger,
Do you still have an '86 wiring diagram? We're troubleshooting some clearance lights and it would really help to know what we're working with!
02-22-2021, 06:26 PM
Originally Posted by nanoplane
I know this is an ancient thread, but I have a 95' Thomas International Vista, 3600 & I'm wondering whether or not you think this might be a good reference for us also? We are having some electrical issues, specifically the fuse for the rear panel / exterior rear lights. The 30 fuse keeps blowing as we are driving down the road and leaving us with no running lights or tail lights. We've changed it 2-3 times driving it the last two days. If this info is compatible with our bus, which has a Navistar T444e then it would be super helpful! Thanks!
05-13-2021, 01:51 PM
You have wires rubbing together or chaffed rubbing the body somewhere for that circuit
05-13-2021, 03:32 PM
Year: 86
Chassis: Ford B700
Engine: 8.2
Originally Posted by ManitobaBus
Hi Jolly Roger,
yes i do PM me and i will try to post them here as well.
05-13-2021, 03:51 PM
Year: 86
Chassis: Ford B700
Engine: 8.2
the documents are showing there age but maybe they will upload.
