My only issue with this idea, is that you are taking insulation from one spot and moving it to another. Their design worked out because they were comfortable with existing insulation on the bus, but others may not have as good. If this was done I'd make sure to insulate the bottom part first, so that when u remove that insulation on the board and put it up where the windows are, you still have good enough insulation on the bottom too.
