11-02-2015, 12:19 PM
Year: 1982
Chassis: International S1800
Engine: DT466 Trans: MT643
Low Water Pump Pressure
Hey gang,
I've been experiencing low water pressure on my bus since I finished it this summer. Ive tried replacing the pump, and all my connections/tubing is 1/2".
When Im connected to city water, I get awesome pressure and all flows well.
When Im boondocking, I get great pressure for the first 3-5 seconds, then I have very little pressure, showering sucks and there's no way Im getting the 3.xgpm that shurflow specs the pump to. This happens with either hot or cold, and on all my faucets.
Here's a video of the problem I made:
What the heck can I do to fix this?!
www.bustoshow.org
Blog: www.lookatthatbus.com
Instragram: @lookatthatbus
11-02-2015, 01:32 PM
check the tank for an obstruction.....
im guessing it pumps all the water in the pipes and accumulator fine, but cant refill the system fast enough. try 3/4 " pex to the pump maybe, maybe the pex line is pinched between the tank and accumulator.
3.5 gpm pump should push a single faucet fine.
11-02-2015, 01:53 PM
Year: 1982
Ive actually already checked the tank for obstructions, and the hoses to and from the pump are the 1/2" ID flexible lines that I purchased from shurflow specifically for mounting this pump.
Im stumped!
11-02-2015, 02:32 PM
Chassis: Blue Bird
Engine: ISC 8.3
There isn't a mention in the video about how the city water connection is made, so I'll assume it's a tee somewhere after the accumulator, and that it all relies on the built-in check valves in the city water connector and pump. This and the decaying pressure and long pump cycle after closing the valve make it look like the accumulator and all else downstream are fine, as turf suggested and you probably already knew.
You could probe its supply wires while the pump runs to be sure there isn't excessive voltage drop causing the pump to run slow. This seems unlikely because the pump sounded like it's running fine, but maybe worth the few seconds to verify anyway.
Seems like a water supply problem. Is the suction line collapsing anywhere? Is the filter unit directional and possibly installed backward?
Try using a short piece of tube to draw water from a bucket on the floor directly into the pump, bypassing the screen/filter. If it pumps fine from there move the bucket and tube upstream toward the tank incrementally until you find the obstruction.
11-02-2015, 03:25 PM
Year: 1982
Pump voltages are good--right around 13v.
I haven't tried putting the pickup tube in a bucket, next time my tank is empty Ill pull the line and put it in a bucket.
I wonder if there is a pinhole leak in my hose coming from the tank to the pump causing the pump to get air bubbles.
And yes, the city water connection is a tee that happens after the pump/accumulator.
I think the next steps are determining if the issue is beforw or after the pump
11-02-2015, 03:44 PM
Charles, I put your issue to the folks at irv2 and so far;
"It appears as his system is pressurizing but then after the faucet is turned on there is no flow. On my Shurflo pump there are screens on the intake side, you may have your friend check to see if these screens are plugged. A plugged screen would allow the system to pressurize but once you try to run water would not provide the volume you need."
Don, Mary and Spooky the cat.
11-02-2015, 03:49 PM
Chassis: Blue Bird
Engine: ISC 8.3
The pinhole leak theory is interesting.
I meant to suggest a new piece of sold-by-the-foot hardware store tube -- just the basic clear vinyl stuff with the braided reinforcement seems good enough for my pump. In suction use it doesn't collapse as easily as the unreinforced vinyl does. With a short alternate piece of tube for this experiment you can avoid questions about pinhole leaks, tube collapse, obstruction stuck inside the tube, or excess length.
11-02-2015, 05:06 PM
is the water level in the tank sufficiently higher than the pump? if you don't have a self priming pump and rely on gravity to fill, you might have some air trapped in there.
i cant pump out the bottom 3" of my tanks because of the height of the pump.
11-02-2015, 06:22 PM
Another: "I agree that the problem is from the pump back to the tank. To test, run a temporary hose from the pump into a bucket of water. If that works, blow out, clean or replace the line back to the tank. "
11-02-2015, 07:14 PM
Engine: 190hp 5.9 Cummins
Pumping into a bucket is nothing like pumping pressure through a shower head.
My pump will have a pressure gauge after the pump for diagnostic purposes.
Braided vinyl hose is garbage. Everywhere I have ever used it becomes a leak in less than a year. If you need a flex line between the pex and the pump, use a stainless flex hose like used on faucets and toilets.
I just watched your video. That almost looks like voltage sag. Does the pump sound like it's slowing down as the pressure drops?
11-02-2015, 07:46 PM
Nat, FROM a bucket not to a bucket.
11-02-2015, 08:30 PM
Year: 1982
Thanks all for the replies and help!
The screen at the pump intake is clear and the line from the tank is already a reinforced--it is this product and doesn't seem to be collapsing under the suction--at least from a visible/tactile inspection. It is made by the manufacturer of the pump, too, so hopefully they knew what they were doing...
I still think the problem is between the tank and the pump, though, and I'll be taking the lines off and pumping out of a bucket once I get a chance to see if that improves things vs pumping from the bottom of the tank,
http://www.amazon.com/SHURFLO-94-591...N8QMWYS6XAB62R
The pump is supposed to be able to dry prime up 6' and the way I have it mounted, it is at the same level as the tank. The pressure is low, even if the water level is above the level of the tank.
At this point, the most probable cause to me, would be some kind of air leak on the pump intake or a hose that is collapsing. Once the tank is empty, I'll toy with different hoses and a bucket of water to see if that helps. Like I said, I already replaced the pump and I have checked in the tank for obstructions. It's always been this way and I am pretty sure that the pump is getting to 55 psi when the faucets are off, but once a faucet is open, it can't keep up. If I turn on the water in the bathroom, the kitchen sick doesn't even work.
It's just hard for me to imagine why it would be having such a hard time sucking water from the tank unless there was a pinhole vacuum leak in the intake line or an obstruction like a collapsed hose. All my fittings are 1/2" minimum between the tank port and pump.
Maybe I'll try and blow out the line between the tank and pump as well....
Thanks again for the ideas, guys!
www.bustoshow.org
11-02-2015, 08:37 PM
Chassis: Blue Bird
Engine: ISC 8.3
One other thought: is water drawn from the tank through a bung low on the tank, or through some kind of dip tube? If a dip tube, is it cut square on the end, and perhaps long enough that it is very close to the floor of the tank...? It could be nearly sealing itself to the tank floor.
11-02-2015, 09:36 PM
Rated Cap: 40 Prisoners
Is there the possibility the wiring is reversed making pump run backwards.
11-02-2015, 10:11 PM
Rated Cap: 19
Is there a good air vent on the water tank?
11-03-2015, 12:24 AM
Year: 1982
Thanks for the ideas!
The outlet is a bung on the bottom of the tank, not a pickup tube.
Unless red means negative, the pump is wired properly ;)
The tank has a 3/8" vent port that is working properly--I can fill with a garden hose full blast with no issues.
I will check the voltage drop, and intake line from the tank to the pump tomorrow when I get back to the bus, sleeping at the old lady's place tonight
11-03-2015, 01:04 PM
Moderator
Engine: DT408, AT545
Rated Cap: 23 500 gvw
I think you have a mouse wedged into one of your tubes.
11-03-2015, 08:39 PM
Rated Cap: 19
Stupid mouse!
11-08-2015, 10:04 PM
Year: 1982
Looks like there was, after all, a mouse living inside the line from tank to pump....
ok, it was just a whole little nest of polyethelyne shavings from, I suspect, when the holes were drilled into the tank for the bung fittings.
Now my water pressure is awesome and I have a new problem--My water tank lasts half as long as it used to!
Thanks guys
www.bustoshow.org
11-08-2015, 10:18 PM
Rated Cap: 19
Glad it was something cheap, if not easy to fix.
