Old 07-31-2009, 05:16 PM   #1
TygerCub's Avatar
Engine: Detroit
luxury in-floor heating
With the floor finally up in my bus, I'm thinking ahead to winter. I found this roll of "in-floor-heating" from Northern Tool and wondered if anyone else is using it?
http://www.northerntool.com/webapp/w...9309_200329309
It's not cheap, but not super expensive either. I figure with two rolls of it placed down the center aisle, it would help keep the central traffic area nice for the feet (especially if it has some radiant insulation under it to direct the heat upward.
At 120 volts / 3 amps / 360 watts, would that be a tremendous power drain on a battery system? Just looking for some ideas before I start laying down flooring.
Old 07-31-2009, 07:10 PM   #2
Duckf00t's Avatar
Chassis: Amtram
Engine: Navstar 190
Re: luxury in-floor heating
Well depends on how much cold weather you'll be in. As well as your floor plan. Ours is a very open plan. I have an 80,000 btu propane shop heater that will melt the paint in minutes... quick heat get it warm. Then use the propane grill I'll install for heat.
The farther you look into the past the further ahead you'll see- George Washinton
https://duckf00tbus.blogspot.com/
Duckf00t is offline   Reply With Quote
Old 07-31-2009, 09:07 PM   #3
GoneCamping's Avatar
As cold as the floor in my bus got last winter, one (or more) of those would have come in very handy. And at only 3amps per unit, I could have run a few of them as I had plenty of power available for it. I went and book marked it for furture reference...
*Cliff*
...Your home has brake lights
1994 Jeep Grand Cherokee
Chesapeake, Virginia
GoneCamping is offline   Reply With Quote
Cabin Heating, Water Heating Locutus Heating, Cooling and Appliances 2 11-01-2014 04:34 PM
Radiant Floor Heating......feedback requested Shawn C Heating, Cooling and Appliances 14 12-30-2012 10:18 AM
Radiant Floor Heating Reference zim Heating, Cooling and Appliances 16 01-08-2011 01:41 PM
Radiant Floor Heating oldog12 Conversion General Discussions 8 08-24-2006 01:05 PM
Modify stock heating system or seak alt heating? phillbus914 Conversion General Discussions 4 09-14-2005 05:14 PM
