Old 02-14-2015, 04:28 PM   #1
macerator pump
has anyone installed a macerator pump for dumping there holding tanks?
I'm going to get a portable one so I can dump my tanks at home, we do lots of boondocking and just a pain in the butt to go to the dump station.
Old 02-14-2015, 04:44 PM   #2
Stu & Filo. T's Avatar
Coachwork: Crown / Pusher
And while we're on the subject I to plan on installing a macerting pump and plan on a 112 gal fuel tank I got out of another bus my ouestion I have is will the pump draw from the tank in I plumb it from the origanal fuel port? it draws from the top of the tank with a tube that goes to the bottom of the tank
Old 02-14-2015, 05:36 PM   #3
Jerry Campbell's Avatar
Year: 1975
Engine: DD 6-71N
I have been using one for about 10 years. The first one started leaking a little so I bought another one and a rebuild kit for the old one. We use it in the summer in the north and when we are on the road in the winter I use the 3" hose which is much much faster. At home we pump thru a 3/4" hose for 100' uphill about 5'. It works great. Just put the 3" fitting on the bottom of the tank and a fitting on the pump to fit on that. I have a 90 deg clear on the pump so the pump sticks out to the side.
Alwthrrider, I don't think a fuel tank will work well for a holding tank. In order to pump solids from a tank you have to have the hole on the bottom and it needs to be 3".
Jerry Campbell is offline   Reply With Quote
Old 02-14-2015, 05:54 PM   #4
I already have a mercerating toilet so there shouldn't be any solids to pump I'm using 1 tank for both grey & black
Old 02-14-2015, 06:09 PM   #5
GB, I put one on my bus and it works just fine though a little loud. I've seen a couple that were run dry--they ate themselves up in short order. Jack
ol trunt is online now   Reply With Quote
Old 02-14-2015, 06:54 PM   #6
Do you have the type where you put it where your 3'' hose attaches , made by flow jet?
tks
Old 02-14-2015, 11:09 PM   #7
Year: 1975
Engine: DD 6-71N
tks
Yes, and I don't know what I'd do without it.
Old 02-15-2015, 09:14 AM   #8
Thank you for all the info, and Jerry its sounds like I'm going with the flojet, thanks for the help
Old 02-15-2015, 09:29 AM   #9
http://steampunkworkshop.com/diy-rv-macerator-pump/
I use a Sewage Solution unit to discharge at home.
dond is offline   Reply With Quote
Old 02-15-2015, 10:57 AM   #10
dond; I read up on the home made one very neat set up. I really like the sewer solution and I almost got one, the problem is I don't always have the water to run it, I like the ideal of no motors. With the flojet I can pump into my dads septic tank and not use his well water(well not so good), also where we are planning on staying at a friends camp I could dump right into his outhouse. There's benefits to both systems.Also the sewer solution is 1/2 the price.
Old 02-15-2015, 12:59 PM   #11
wash with gasoline's Avatar
The impeller versions won't last long self priming up hill, the diaphram ones don't mind priming themselves and will last much longer if they are above the tank of yuck
Dry with match
wash with gasoline is offline   Reply With Quote
