10-03-2019, 11:12 AM
Chassis: Bluebird
Engine: Cat. 3116
Rated Cap: 53
Making a smoother ride.
Hello all,
My wife and I just purchased a 1997 GMC Bluebird. It is a 53 passenger bus. We plan to convert to a skoolie. However, the suspension is kind of rough. Is there a different size tire I can use to give it a smoother ride? It currently has 9R 22.5 tires on it. Also open to any other suggestions. Look forward to hearing from you all.
Thanks
10-03-2019, 11:28 AM
Year: 1954
Coachwork: wayne
Engine: cummins 12 valve
budget
what are you willing to spend? how much you will spend will dictate what can be done. I spent $7000 on my suspension.
william
10-03-2019, 12:11 PM
Coachwork: Thomas / international
Engine: Dt 360/ spicer 5 speed
Rated Cap: 42
Buses are designed to carry a lot of weight and to operate loaded most of the time so the suspension is gona be stiff. As you progress on your conversion and put more weight into the bus, the ride she get better.also, replace your shocks as they are often overlooked.
10-03-2019, 12:14 PM
I ran into a gent who had removed one or more leafs from the spring pack and added air bags. He was very happy with the results.
10-03-2019, 12:20 PM
THIS!!
an empty bus is the worst ride quality you will have.. when loaded with your conversion and added weight of water tanks, etc it will ride better..
HOWEVER..
like easgle said, the suspension is stiff to handle the weight.. you also have rock-hard tires you are riding on. a regular car you typically ride on 40 PSI or less of air pressure which makes the tires fairly soft.. and they help to absorb road bumps.. esp small but pointed bumps like expansion joints... car tires re-shape as you hit the bump and soften the blow.. along with a softer suspension..
in your bus your tires are going to likely be 95-100 (or more) PSI.. that in and ofitself helps to contribute to a stiffer ride quality... buying a bus with rear or full air ride is a big improvement or a fully leaf-spring suspension.. but still is going to be stiff...
10-03-2019, 12:44 PM
Originally Posted by Humphrey4178
Hello all,
Thanks
Is your bus a lower bus?
Is it a flat floor or do you have wheel wells?
With your tire size I'm guessing its a lowrider type bus. If so- those just ride rough, not a whole lot you can do.
10-03-2019, 12:45 PM
I've seen enough buses for sale with broken leaf springs to be skeptical of this approach, at least for long term durability.
10-03-2019, 12:48 PM
I have spring suspension all around. Honestly, the bus rides far better than I expected it to.
I thought that I was going to have to spend some $$$ to upgrade. After taking 300-400 mile trips both loaded and empty I don't think that I will need to do anything to it.
I used it as a moving truck when I relocated across the state. Drove great and the ride was decent.
10-03-2019, 12:50 PM
Bagging up a suspension is common practice.. the 1 ton dually guys do it all the time to help with 5th wheel ride quality and weight management..
ive not seen a bus or big rig that had a hybrid approach to springs.. they are all either bagged or are spring..
EC is right smaller tires definitely ride rougher.. unless im fully loaded with a group of people or bunch of equipment in my red bus with 19.5" tires it rides rough.. even with air ride.. when im fully loaded that bus rides really smooth
10-03-2019, 01:07 PM
That's what got me looking. If I said that my 3500 rides like a buckboard empty, I would be insulting buckboards. I was considering options to smooth the ride without sacrificing hauling capacity.
Regarding tires, it seems to me that it isn't just about size but more about sidewall height. Am I thinking correctly?
I shed the 19.5's on my truck for low profile 22.5's. I can haul more but it rides much worse. The gent at the tire store told me that if I went to 11r22.5's the ride would improve. That won't happen until I wear these out.
10-03-2019, 01:18 PM
Rated Cap: 42
Adding airbags alone to a 3500 1ton isn't going to make it ride any better unless you throw some weight into the equation or modify the suspension otherwise. Airbags are usually added to those trucks to increase load capacity. A School bus is going to be the same deal, it's gonna ride stiff until it's loaded down a bit. Personally, I lucked out and found a bus with air ride in the rear. Front hits hard on bumps and the rear end glides right over.
10-03-2019, 01:51 PM
You missed the part of my post about removing leafs from the spring pack along with the air bags.
10-03-2019, 02:04 PM
Rated Cap: 42
[QUOTE=PNW_Steve;352026]You missed the part of my post about removing leafs from the spring pack along with the air bags.[/QUOTE
sorry, I didn't see that part. Just wanted to clarify for any newbies
10-03-2019, 02:41 PM
Your PM box is full, go empty it.
10-04-2019, 03:58 AM
I have never really paid any attention tothe PM inbox level. Perhaps I'll take a closer look next time I receive a PM.
10-04-2019, 11:11 AM
Not yours, ECCB's
10-04-2019, 11:18 AM
Not yours, ECCB's
I made a bit of room.
02-14-2020, 02:24 AM
Chassis: fs65
Engine: 7.2 catapillar 3126
Rated Cap: 41 students
So I searched around and found this thread so I'd like to pose a question...a *hypothetical* question...
if someone with a 2003 thomas bus with leaf springs in the back with a gvwr of over 25k weighed under 16k lbs after a full build out and was looking for a softer suspension, could that individual EITHER
remove a leaf or more from the springs to soften the rebound OR remove the inner rear wheels and run single outer rear wheels (given that the tires can definitely hold the weight)
comments?
@drivingdharma
02-14-2020, 03:25 AM
Chassis: IH
I'd not "single out" the rear wheels. Cops seeing this may (and likely will) use it as a reason to stop you, and more to the point, the whole thing is engineered to use dual tires. It places undue "twisting" stress on the wheel bearings and the tires are likely to end up overloaded. Much better to make sure the shocks are good and modify the springs. I would *VERY* strongly advise visiting a professional spring shop for this.
02-14-2020, 05:56 AM
Engine: 345 international V-8
comments?
Yes to removing leaves. This is pretty standard to add or subtract leafs to get the correct weight capacity, as long as you stay within the axle limits.
