Old 11-02-2012, 12:27 PM   #1
Year: 87
Chassis: International s1700
Engine: 6.9 internatiional
Marine battery selector switch
I picked up one of these. hopefully i can use it rather than a battery isolator. looks pretty sturdy too
http://cgi.ebay.com/ws/eBayISAPI.dll?Vi ... 1088951235
proconsul100 is offline   Reply With Quote
Old 11-02-2012, 10:09 PM   #2
Year: 87
Re: Marine battery selector switch
John,
i was thinking the same thing, good to jump the coach batteries with the house batteries in a pinch, and to control charging. i will post better pictures of it when it arrives
Old 11-10-2012, 10:22 PM   #3
Year: 87
i got the switch today. here is it:
Old 11-11-2012, 09:44 AM   #4
kimberlink's Avatar
Engine: DT466 / AT545
Rated Cap: 71
How would one hook this up in order to accomplish the
? I'm drawing a blank, may be too early, not enough coffee...
The most terrifying words in the English language are: I'm from the government and I'm here to help.
Ronald Reagan
https://s1253.beta.photobucket.com/us...k1961/library/
kimberlink is offline   Reply With Quote
Old 11-11-2012, 10:46 AM   #5
Year: 87
just as to can tie cord and house batteries together for charging, you could use the house batteries to start if for some reason the coach batteries die. you could also choose to only charge house or only choose coach. prehaps this might help
Old 11-11-2012, 03:37 PM   #6
bapos's Avatar
Engine: DT466E/MD3060
Looks like a good switch. Ive seen them on there and always wondered how well they will work out. Im not there yet but let us know how they work out. Might be worth getting and sitting till im ready to install.
bapos is offline   Reply With Quote
Old 11-12-2012, 01:19 AM   #7
Moderator
crazycal's Avatar
Engine: DT408, AT545
Rated Cap: 23 500 gvw
You've got four settings. Say 1 is starting battery. 2 is your house batteries. 0 is off. 1+2 is both batteries. If you have a dead starting battery, you would switch from 1 to 1+2 and use both batteries to start your bus. I don't know if I explained that well enough. The reason for that switch on a boat is to always have a second battery as backup so you can get home.
I'm hungry!
You Gotta Let Me Fly
Old 11-16-2012, 10:53 AM   #8
Diesel Dan's Avatar
Engine: DT466/AT545
I've been thinking of getting one of these as well. My intention would be to use my alternator to charge my house batteries while driving down the road. I assume if I set the switch to connect both sets of batteries (chassis and house) that the charge from the alternator would go equally to both sets of batteries? Or would the charge go first to the batteries with the lowest charge? I'm thinking I could get a gauge to monitor my chassis battery so I would only send the charge to the house batteries if I knew the chassis batteries were full. Am I making any sense at all?
Gallery:
Conversion Thread:
viewtopic.php?t=4959
Old 12-14-2012, 12:35 AM   #9
Chassis: International S1800
I actually have the blue-sea systems "add a battery" kit. It includes a red rotary 3 position switch. The positions are "Off", "On", and "1+2", the latter being labelled Emergency. It bridges the starting batteries and the house batteries together.
http://bluesea.com/products/7650
The other component of the add-a-battery system is the isolating/combiner. When either side of the combiner is showing above 13.x volts, it combines the house and the vehicle systems so that whatever your charging source (engine, when underway, or shore/gen power when moored) is charging the whole vehicle.
Great system. I am super impressed with Blue Sea products. (I also have thier fuse block and one of their 225A fuses)
thrash is offline   Reply With Quote
Old 06-04-2021, 05:36 AM   #10
Chassis: 202905
Engine: 46095366
Rated Cap: 54
It seems that the Battery selector switch with 3 or 4 functions
does the same function as a battery isolator kit, Is this true? Do I need just one or the other? or are both still helpful for all functions?
twotbgrar is offline   Reply With Quote
Old 06-04-2021, 09:59 AM   #11
Rwnielsen's Avatar
Chassis: TC2000, 40' MPV
Engine: 5.9 Cummins/B300 trans
Rated Cap: U/K
This is a 9 year old thread. You should really start a new thread if you want pertinent information.
Anyways...welcome to the circus 😊
Rwnielsen is offline   Reply With Quote
Marine Water Heater lornaschinske Plumbing, Water and Waste 1 04-27-2011 07:24 AM
Cast Iron Marine Wood Stove lornaschinske Conversion General Discussions 12 02-24-2011 01:38 PM
Main Battery - Starting Battery Group 31? 8D? Tone Conversion Tutorials and How-to's 5 04-16-2009 05:02 PM
12v power selector switch source TheHokieHoopty Conversion General Discussions 7 09-04-2006 08:44 PM
120V Marine 5 gallon Water Heater Eric von Kleist Classifieds | Buy, Sell, Swap 4 12-08-2004 08:32 AM
