Old 04-26-2011, 10:40 AM   #1
lornaschinske's Avatar
Rated Cap: 89
Re: Marine Water Heater
I don't believe that Atwood makes a heat exchanger type water heater for the RV market. So if you want one, you would have to go to a marine version.
Most things that are not "approved" for RV use can still be used in an RV. Several years ago, I contacted some folks who made tankless water heaters about whether or not they could be used in an RV even though they were not "approved". The company told me that the company pres, VP and most of the engineers (and many of the workers) were into RVing and had installed them in their RVs quite successfully (these were vented domestic LP tankless water heaters). When I asked WHY they weren't "RV approved" they said it was simply a matter of $$. Too many $$ for a small market segment. To get approved for the RV designation would take years of testing and huge amounts of paperwork, time and $$. Then they would have to market to the manufacturers (who weren't interested as they want the cheapest product they can get by with) and find outlets for the RVers... who weren't all that interested.
So the marine heat exchanger would be fine. Most marine things are fine. There are limitation to the toillets though since some are designed to use sea water and to flush below the water line... plus they are more $$ than a well made RV toilet (like the china Sealand Traveler... which used to be Mansfield Traveler).
Fulltime since 2006
Old 04-27-2011, 07:24 AM   #2
RevBill's Avatar
Coachwork: - Still Shopping -
Chassis: - Going Medium/Large -
Engine: - DT466 Desired -
.. good price .. nice find .. the addition of a heat exchanger really opens up some possibilities .. kewl stuff ..
.. found this .. may or may not apply .. seems to cover just about every model they make .. http://manuals.adventurerv.net/Atwood-W ... ervice.pdf ..
Chance favors the prepared mind. - L Pasteur
Luck is the residue of good planning. - B. Rickey
Travel is fatal to prejudice, bigotry, and narrow-mindedness ... - M. Twain
RevBill is offline   Reply With Quote
Rv Fridge and Rv water heater kenny76 Classifieds | Buy, Sell, Swap 6 06-01-2014 11:13 PM
Water heater placement bluebird90 Conversion General Discussions 1 08-12-2013 08:31 PM
110v water heater Diddly Conversion General Discussions 3 07-11-2011 12:25 PM
Bus engine as a water heater Steve Conversion General Discussions 20 07-07-2006 01:53 PM
120V Marine 5 gallon Water Heater Eric von Kleist Classifieds | Buy, Sell, Swap 4 12-08-2004 08:32 AM
