Old 05-08-2016, 02:16 AM   #1
tincaneasybakeoven's Avatar
Year: 95
Coachwork: Amtran ss-33
Chassis: Int 3800
Engine: dt444E
Rated Cap: 29,000
marvin the martian raygun air conditioning
Buses are airflow sloths, So i designed an airflow gun to help get high pressure clean air into the sojourning device interior; also known as bus interior by many. this worked so well that i had to don a light jacket and put one over my legs to stay warm on a recent night trip (5-1-16) the frontal area is a 6"x 12 " register duct (72 square inches) flowing into a 6" x 24" sheet metal duct and then into a 4" pvc. clean out sweep and then into a pvc. 22 degree street ell. high flow high pressure air by such an unusual device i nicknamed it marvin the martian ray gun a.c.
Imgur: The most awesome images on the Internet
claim common law i, a man; claim.... on facebook
if your not a man our doing it all wrong-kp
tincaneasybakeoven is offline   Reply With Quote
Old 05-08-2016, 02:24 AM   #2
Is that for use while in motion?
Roll Your Own Build Thread
Old 05-08-2016, 06:00 AM   #3
that will bring some air in... and the bugs and the rain too
-CHristopher
Old 05-08-2016, 06:53 AM   #4
somewhereinusa's Avatar
Chassis: AARE
Engine: 3116 Cat 250hp
I wouldn't want to behind you when that thing comes off.
Old 05-08-2016, 06:55 AM   #5
jester's Avatar
Chassis: RE200
Engine: 7.3L Navistar T444E
that is quite the contraption! man i really hope my family never has to drive behind you though, perhaps a LOT more securing is in order. when , not if, that thing flies off pray that it doesn't hurt anyone!
the idea is sound though. need different materials, maybe hood scoop off old hot rod would work safer and better, or something that shape. then you could put cover on it and be able to open and close it from the inside. maybe even be able to swivel it to not be a water grabber when raining.
check out my build pics
http://www.skoolie.net/forums/member...albums833.html
or my random writings... at
www.roadrunnerlogik.blogspot.com
jester is offline   Reply With Quote
Old 05-08-2016, 08:37 AM   #6
That was my thinking.
Old 05-08-2016, 02:34 PM   #7
Robin97396's Avatar
My old Ford shorty just has a simple air scoop on the side with a flap to block it off. If you've ever driven through bees on the highway you'll be glad you can close the scoop.
Old 05-08-2016, 10:24 PM   #8
Coachwork: tc2000
Chassis: blue bird
Engine: cummings 5.9
HAHAH, that is great! I'm dying laughing. You really need to secure that thing WAY more.
But The idea of moving air around in there is a good one. I like the hood scoop idea, or maybe one of those fresh air vents you see on enclosed trailers, but make it swivel like jester said.
scootie is offline   Reply With Quote
Old 05-09-2016, 12:07 AM   #9
Robin97396's Avatar
It would be nice if the vent could be adjusted from inside so it would either blow fresh air while facing forward, or draw air out by facing backward.
Old 05-09-2016, 12:08 PM   #10
Chassis: Blue Bird
Engine: ISC 8.3
It does look... intimidating. Like a giant vacuum cleaner with an itty bitty intake racing down the road, slurping up.. whatever things dwell at 9 ft above the pavement.
How about an RV roof vent cover turned to face the "wrong" way so it's an air scoop instead?
Old 05-09-2016, 12:17 PM   #11
years ago a group of us were on a trip in an old Land-rover somewhere in arizona.. We tossed the A/C belt somewhere along the way.. the people in the back seat hated us opening the windows.. but below the windshield it had these vents that popped open.. they had screens in them to catch any debris..
yeah the screens Worked when we hit that mob of bugs.. some kind of bees or flies.. the screens caught the BUGS but the 2 of us in the front seat got our faces sprayed with bug GUTS!!
the next town we found we hit the Local truck stop then Napa to buy a socket set and an A/C belt!!
Old 05-09-2016, 04:26 PM   #12
With 4 big round holes already there...the fauxaldiyraygunmailboxsewervent...didn't need to be built
kind of looks like a humming bird feeder or old Motorola player, depending on paint choice, why OP? is it just a code when you where bored?
If not I apologize and add that would get you pulled over in a lot of locales
Old 05-09-2016, 05:07 PM   #13
Chassis: International 1753
Engine: 6.9 International
I'm not much of a fan of what you have here for all the reasons others have mentioned. I can't tell from your avatar, but you should have a fresh air supply on your bus controlled by a knob by the driver. The exterior vent for that is here circled in red
If you don't have that, I would think you should still have some sort of external air source to come out of the vents.
Old 05-10-2016, 10:14 PM   #14
Chassis: TC2000 RE
Engine: 8.3l Cummins
Mega maid!
aaronsb is offline   Reply With Quote
Old 05-10-2016, 10:39 PM   #15
Chassis: Genesis
SHE'S GONE FROM 'SUCK' TO 'BLOW'!
Timelord is offline   Reply With Quote
Old 05-11-2016, 01:12 AM   #16
Year: 95
Chassis: Int 3800
Engine: dt444E
Rated Cap: 29,000
what is illegal or unlawful about the air vent? is unconventional against the law or codes? provide evidence and not opinion.
Old 05-11-2016, 01:23 AM   #17
Year: 95
Chassis: Int 3800
Engine: dt444E
Rated Cap: 29,000
fresh air opening is flat, on the side, by small louvers in a no pressure zone and provides near zero airflow. when boundary layer air adhesion is lost the flow becomes negative. the air scoop survived a 280 mile trip without movement as configured so the detractors would have followed from driveway to driveway without event.
just sayin..........
Old 05-11-2016, 02:34 AM   #18
Engine: Cat 3126b 250 HP
Rated Cap: Only 1 seat
Think it would stay on in one of those Texas Tornadoes you guys are famous for???
Old 05-11-2016, 05:16 AM   #19
Year: 95
Chassis: Int 3800
Engine: dt444E
Rated Cap: 29,000
yea everybody missed the 6" screw band clamp on the front near the register box sheet metal. but yet they trust pressurized air oil and water to the same screw band clamps. very "dual minded" imo.
Old 05-11-2016, 07:24 AM   #20
jester's Avatar
Chassis: RE200
no one was trying to offend you. it just plain physics, you have a bunch of plastic and sheet metal bailing wired to the windy roof of a school bus traveling fast. pipe clamp or not man that just not safe. i can pull a sheet metal screw out so i know the wind can. i think if you just put a plumbing sweep out any of the windows on side of bus you would have same result with half the risk of hurting someone. besides its the people behind you that you are putting in harms way, not you, doesn't that worry you?? and you really dont think the police are going to pull you over for it??
all the air oil and water that is clamped is to the frame or thick steel and WAY out of the wind, or path in which something, anything, can hit it or damage it. like i said , think of the people behind you on the road.
by the way i liked the ingenuity of it and just suggested safer materials.
