Old 06-26-2019, 10:52 PM   #1
Engine: Cummins 8.3
Rated Cap: 25
MaxAir vent in fiberglass roof
I want to replace my roof emergency exits with MaxAir Deluxe vents. Of course, the vents are 14x14 and the exits are 23x23. I saw that some people just add steel sheets and supporting brackets. My roof is made out of fiberglass. Should I still use metal or are there any alternatives (I am a newbie in fabrication)?
Elmix is offline   Reply With Quote
Old 06-27-2019, 12:05 AM   #2
Traveling
Most use a piece of sheet metal to close the hole and mount the fan in the middle of that. I instead used a piece of tinted Lexan and then mounted the fan in the middle. Not thay I've removed so many of the school windows and only replaced some with RV windows it's a bit darker in and I appreciate the extra light coming through much more now. Also replaced the front hatch and the passive vent with Lexan windows.
Old 06-27-2019, 12:08 AM   #3
Engine: Cummins 8.3
Rated Cap: 25
Wow, I was just thinking about using lexan. How thick is your sheet? Also what did you use to secure it to the roof?
Old 06-27-2019, 12:23 AM   #4
Traveling
1/8" is all you need. Make sure it is Lexan and not plexiglas. I ordered 2-26" x 26" x 1/8" tinted gray Lexan on eBay from a seller "popdisplays" . I paid a premium for these knowing I would have too much "scrap" left if I bought a 4' x 8' piece. I used "cold" butyl tape and then stainless steel panhead screws, predrilled about every 2". Once I installed the screws using the impact I trimmed the excess butyl tape showing and then ran a bead of sealant around that. They don't leak. Trimming inside is going to be more work, but doable. 2 inside trim rings instead of one, one being fabricated.
Old 06-27-2019, 12:32 AM   #5
Engine: Cummins 8.3
Rated Cap: 25
Thank you so much! I thought I’d need at least 1/4 of an inch. Actually, I have ordered already lexan sheets from this ebay seller. I want to make a front door out of lexan.
