Old 05-28-2012, 07:16 PM   #1
Kathy WI's Avatar
Mesh ceiling
What's the purpose of having part of the ceiling made of mesh type holey metal and the rest solid metal? My bus has the mesh stuff in the front about five feet. I don't particularly like the look of it and I was wondering if it matters if I cover it.
Kathy WI is offline   Reply With Quote
Old 05-28-2012, 07:46 PM   #2
TygerCub's Avatar
Engine: Detroit
Re: Mesh ceiling
Yeah! I wanna know too!
Old 05-28-2012, 07:55 PM   #3
bus-bro's Avatar
Engine: 3208 na boat anchor
Re: Mesh ceiling
Less noise.
Old 05-28-2012, 08:46 PM   #4
Re: Mesh ceiling
Could you snap a pic of this stuff for those of us who don't have a mesh ceiling please.
Just a guess having not seen it--could it have something to do with ventilation? My old bus has a few slots in the inside roof just in the drivers area which lead to a screened opening in the outer roof to provide ventilation.
Old 05-29-2012, 05:56 AM   #5
Re: Mesh ceiling
I think it is both,we were discussing this last night,there is less echo at front of bus where the mesh is,also we have a vent in the center near front
I was looking up at it and noticed...sunlight ...I guess they had a radio antenaee or strobe mounted there,great place for water to get in I'm just glad we had that mesh so we could see it early
Old 05-29-2012, 10:10 AM   #6
browncrown's Avatar
Rated Cap: 79 at Birth
Re: Mesh ceiling
The mesh ceilings are for acoustics to help deaden the noise. It shouldn't matter if you cover them up.
BC
My Conversion Thread: https://www.skoolie.net/forum/viewtopic.php?f=9&t=3065
Old 05-29-2012, 12:53 PM   #7
Kathy WI's Avatar
Re: Mesh ceiling
Here are a couple pics of the mesh ceiling.
Old 05-29-2012, 05:07 PM   #8
browncrown's Avatar
Re: Mesh ceiling
Those ceilings really do help with the noise. But I found on my bus, the heat on a double ceiling of metal was overbearing so I think you'll find you want to cover them up for that purpose alone. I glued down styrofoam type insullation on my roof and then covered it with carpet. Holding up well so far, however you do have to now occasionally vacum the roof
BC
Old 05-29-2012, 06:13 PM   #9
Re: Mesh ceiling
I am going to def. cover the "drivers area" all surfaces with something to lessen the thermal bridge.(and soak up and dampen noise)
Kinda like a car when if you touch the metal it's hot and if it has anything on it it's "cooler" to the touch and to the IR gun
Old 05-29-2012, 09:18 PM   #10
Kathy WI's Avatar
Re: Mesh ceiling
I never thought about covering it to make it cooler. Living in Wisconsin, I'm usually thinking in terms of insulating against the cold, but it really gets blasted hot in there. Covering the ceiling will be my next project. Speaking of which...what kind of adhesive have you found that isn't affected by the heat? I've found that anything heavier than paper falls off the wall if I use hot glue or double stick mounting tape. It doesn't fall off from bouncing around; mostly after the bus has been sitting in the heat I find that stuff has come unstuck.
Old 05-29-2012, 09:50 PM   #11
roach711's Avatar
Rated Cap: 19
Re: Mesh ceiling
I wanted to glue foil-backed insulation board to the fiberglass walls and ceiling of my bus so I went to the liquid nails website and asked which of their products was best to use. They suggested a polyurethane based adhesive for my application. Your best bet is to do the same. Tell them what you're gluing to what and the temperatures involved and they'll give you their recommendation.
I had to prop my insulation panels tight against the wall or ceiling overnight before they would stay in place.
The Roach Motel
Old 05-30-2012, 09:55 AM   #12
lornaschinske's Avatar
Rated Cap: 89
Re: Mesh ceiling
The vent works like an attic vent. It allows hot expanding air to escape thru the vent when he bus is closed up rather than thru the front wind shield. We kept ours even though I will eventually add a couple of marine solar exhaust vents.
Fulltime since 2006
Old 05-30-2012, 10:12 AM   #13
browncrown's Avatar
Re: Mesh ceiling
I used the heavy duty Liquid Nails for my ceiling insullation and the carpet as well as the wood bows covering the edges of the carpet sections. Like Roach said, it may depend on what kind of surfaces you are trying to glue to. The area where I live has summer temps daily in the 90's and often around 100, so someitmes the inside temp of the bus gets up toabot 120 if it sits. I have had the ceiling done now for about 3 years and no problems as of yet with anything coming down.
BC
Old 06-03-2012, 09:30 PM   #14
Kathy WI's Avatar
Re: Mesh ceiling
I did the ceiling this weekend and it turned out pretty cool. I used a combination of Liquid Nails and hot glue; we'll see how it holds up. The Liquid Nails says it works in temperatures up to 180. The new ceiling is much more interesting to look at while lying on the couch.
Old 06-04-2012, 05:33 AM   #15
TygerCub's Avatar
Engine: Detroit
Re: Mesh ceiling
Awesome!
Love the visual details you've put into your bus. But do you ever find that much visual texture makes the space seem smaller?
Old 06-04-2012, 05:45 AM   #16
Re: Mesh ceiling
Awesome!
It must ....since the couch is in the driving compartment
Very cool
Old 06-04-2012, 10:01 AM   #17
Re: Mesh ceiling
if the mesh ceiling quiets the drivers area a bit, i bet pieces of it say one inch away from the generator compartment walls would act to reduce further sound in that...
Old 06-04-2012, 04:34 PM   #18
Kathy WI's Avatar
Re: Mesh ceiling
I really don't think it seems smaller. When I was looking at regular RVs, it seemed to me that elbow room was a big factor in how big the space seemed. Like if it has a lot of cabinets up high so you have to watch your head, or the bunk beds in back that mine used to have, where you have to squeeze down a narrow aisle. I think my bus feels bigger than a normal RV because there isn't any bulky stuff up high and all the original windows are still there.
Ceiling lights tomas_maly Conversion General Discussions 8 05-30-2013 10:02 PM
Carpet on ceiling Soundman1 Conversion General Discussions 12 08-04-2012 02:28 PM
Ceiling ventilation fan Atridox Short-Bus Conversion Projects 2 08-02-2011 02:12 PM
Anchor in ceiling AmyThompson Conversion Tutorials and How-to's 2 12-10-2010 10:39 AM
Texture on the ceiling Kirbystud Conversion General Discussions 9 03-15-2006 07:25 AM
