this is the product l would use to repaint the bus, two tone, blue and white, with a Greyhound like 'swoosh' and a designer sleddog team coming at you painted on the sides
Rapid Dry Alkyd Enamel
Features
More Information
SDS / TDS
Rapid Dry Alkyd Enamel is a high-performance, quick-dry, rust-preventive shop enamel formulated for use on ferrous metal substrates. Rapid Dry Alkyd Enamel is excellent for use in shop application facilities in the fabrication market, and also is ideal for use in the industrial refurbishment market as an implement, dumpster, machinery, or construction enamel.
Tack free in 10 minutes – recoat in 2 hours (25 °C [77 °F], 50% RH)
Excellent gloss and colour retention
Spray only – airless or HVLP systems
No orange peel
Intended for shop and OEM applications only
Hard, scratch- and impact-resistant coating
