Old 06-11-2012, 09:46 PM   #1
Engine: DT466/AT545
Modified sine wave for a fridge?
Okay, I apologize in advance for stirring up trouble. This topic often gets people riled up - but I gotta ask: How many people have successfully run a refrigerator off a modified sine wave inverter for a reasonably long period of time (years). What I've gathered from previous discussions is that electronics are okay to run on MSW, but anything with a motor is better off with pure sine wave. Am I remembering that right? Anyways, I don't want to spend all that money on one of those pure sine wave inverters if I don't have to. I'm currently running lights, fans, and electronics on my 1500 watt modified sine wave inverter with no problems, but I'm getting ready to put in a fridge so wanted to see if anyone has any real-world experience with this to share.
Thanks!
Dan
Old 06-11-2012, 11:40 PM   #2
usmcbay's Avatar
Coachwork: Thomas MVP
Chassis: Saf-T-Liner ER
Re: Modified sine wave for a fridge?
I'm interested to see the replies....
No answers here tough...
Here's my Bus Conversion...
viewtopic.php?f=11&t=12202
usmcbay is offline   Reply With Quote
Old 06-12-2012, 03:44 AM   #3
there was a pure sine wave on eBay a week or so ago that was used, but i had already spent more than i should have this month so i didnt bid on it...
all i have is a modified sign wave one, and have only run the micro and tv system on it, and that works fine, runs the smaller ac ok also.. but not at the same time.
i think eventually i will get a real spendy pure sine wave inverter, as well as something like a 8-12k diesel gen set, since that is the right way to have things in a conversion.
Old 06-12-2012, 04:01 AM   #4
I am looking to do similar,except use a 5cu ft freezer converted to fridge.
I have read yes and no about invertors.
The fridge will use about 3 amps running(I am going withway highside and using 5amps fkor the math) so some say 8 to 10 times that to start the motor so 50 amp startup max.that would be a 6000watt surge needed.(problem is it works fine on a 15 amp 120 circuit so those number must be wrong)
Ithink that is way off tho' based on a 3000watt generator will easily power a fridge and small ac(unless they both kickon at the same time.
I am going to try it with a 1500 watt(3000) surge invertor,I have a couple laying around,it may work,may not
Old 06-12-2012, 07:19 AM   #5
somewhereinusa's Avatar
Chassis: AARE
Engine: 3116 Cat 250hp
Rated Cap: Her, me and Molly
I ran a refrigerator on modified sine wave in my semi for years. Never had a problem. I'm also running the same setup in my camper. I can't tell any difference
running shore power or inverter. My latest inverters have a readout showing amps. I've never seen either one go above 80. Usually they do about 70 on start then drop off to
about 30. Your mileage may vary.
Old 06-12-2012, 08:22 AM   #6
Good to hear that,lot's of people have said that they run small dorm and single door fridges off of 1500w inverters...but way to many cyber-neer's
What size fridge dorm type with what inverter size?just curious
Old 06-12-2012, 10:01 AM   #7
lornaschinske's Avatar
Rated Cap: 89
Originally Posted by Diesel Dan
... What I've gathered from previous discussions is that electronics are okay to run on MSW, but anything with a motor is better off with pure sine wave...
It's the other way around... MSW for everything but electronics. SOME microwaves have problems with MSW. My theory is this... Plug it in and see. I know a lazer printer is Pure sine only but an ink jet is just fine on MSW. It's mostly "some" that don't like MSW on electronics.
MSW will power most anything. Start with MSW and if something objects, buy a little PSW unit. But I am a firm believer in using multiple inverters (that must be kept within 10 ft of battery bank) rather than one large one. I like to know that if one unit poops out, I can pull another unit into service temporarily. But mostly it's because I have one 750Watt(?) inverter now and may add another one later. One for lights and front TV. One in the rear for desktop computer, printer and rear TV. I don't really NEED the 2nd (rear) inverter but I would like one.
Figure to DOUBLE running watts for startup motor surge (minimum estimate... to be safe 2.5X and figure the fridge runs 24 hrs for load)
Fulltime since 2006
Old 06-12-2012, 10:24 AM   #8
I figured in 30 AH for the fridge should be less in reality(if we don't consitently open and close it...also reason for using a freezer,cold air wont "roll" out)
Old 06-12-2012, 12:27 PM   #9
Engine: DT466/AT545
I will be getting a dorm fridge/freezer like this one: http://www.bestbuy.com/site/Haier+-+2.7 ... Id=1931487
There are no technical specs for Amp draw on this website, but I'm guessing it will only be like 1 or 2 running Amps. I have a 1200 watt MSW inverter, or maybe it's 1500 watts, I'll have to look. But either way, I think it will be fine even with the surge when the compressor kicks in. At most I'll be drawing 4 or 5 amps for a couple seconds.
Old 06-12-2012, 12:54 PM   #10
those are the type of numbers I am expecting also
help with fridge vent lornaschinske Conversion General Discussions 4 08-28-2016 06:33 PM
Pure Sine VS Modified Wave Inverters TygerCub Conversion General Discussions 8 08-05-2012 09:06 PM
Smoothing out a modified sine wave AC signal icnivad Conversion General Discussions 2 02-06-2012 06:37 PM
Sine wave inverter alert Ob1 Conversion General Discussions 6 09-22-2010 08:15 PM
Propane Fridge ezbme Everything Else | General Skoolie Discussions 5 05-08-2009 09:17 AM
Copyright ©2000 - 2016, vBulletin Solutions, Inc.
