Old 08-23-2008, 09:05 AM   #1
Year: 1981
Engine: IH 392
Rated Cap: 53
moisture between window glass
Obvious question...
jerhutch is offline   Reply With Quote
Old 08-23-2008, 10:36 AM   #2
the_experience03's Avatar
Re: moisture between window glass
I want the answer too...
Old 08-23-2008, 01:39 PM   #3
Moderator
crazycal's Avatar
Engine: DT408, AT545
Rated Cap: 23 500 gvw
Come on Smitty, it's soo obvious.............................. Isn't it?
I'm hungry!
You Gotta Let Me Fly
Old 08-23-2008, 09:03 PM   #4
GoneCamping's Avatar
Not all that obvious to me either, I have no overlapping glass to get moisture inbetween?
*Cliff*
...Your home has brake lights
1994 Jeep Grand Cherokee
Chesapeake, Virginia
GoneCamping is offline   Reply With Quote
Old 08-24-2008, 01:15 AM   #5
My windows are double paned. Between the pains in the front 2-3 windows on each side there is condensation trapped. Now eliminating the pathway the condensation took to get in there is easy enough, but getting it out first is not so obvious.
Old 08-24-2008, 09:18 AM   #6
Griff's Avatar
Year: 1982
Chassis: IH S1723
Engine: IH V345 Gas V8
OK, if it got in, you can get it out. Try using a heat gun or hair dryer to mildly heat the window until the condensation evaporates, then seal it.
It will probably take a little while per window. You will have to use very mild heat it bcause it will have to evaporate through the same leak that allowed it to enter.
Hope this helps!
Griff
Griff is offline   Reply With Quote
Old 08-24-2008, 10:04 AM   #7
SeanF's Avatar
Chassis: IHC
Engine: Dt360
Rated Cap: 19
If you can manage it, chuck a bunch of silica beads between the panes to absorb the moisture. My two front side windows are double-paned and there's about (guesstimate) about 1/8th cup of silica beads in between the panes. They never fog.
I'd go this route since there is a good chance that it will never be a 100% dry environment in there. Get it as dry as possible, add the silica beads, seal it up, and hope for the best.
Bus conversion/info here
SeanF is offline   Reply With Quote
Old 08-25-2008, 07:34 PM   #8
Year: 1981
Engine: IH 392
Rated Cap: 53
Where can I get silica beads?
Old 08-26-2008, 10:12 AM   #9
SeanF's Avatar
Chassis: IHC
Engine: Dt360
Rated Cap: 19
Here's 25 lbs:
http://www.compressedairdesiccant.com/i ... ucts_id=61
If you google with keywords "desiccant beads" you should get a lot of hits. I only saw the little packets used for shipping & storing electronics, and the big 25+ lb bags. I'm sure there's an in-between..somewhere...
Winterizing/Mold/Moisture protection for our bus opus Conversion General Discussions 2 02-15-2013 07:49 PM
Glass Navistate Conversion Tutorials and How-to's 4 02-26-2010 11:41 PM
Bullet Proof Glass jackdenial Classifieds | Buy, Sell, Swap 0 01-25-2010 05:53 AM
Ridding Moisture in a Skoolie Ottomobile Conversion General Discussions 10 04-23-2007 08:36 AM
Glass Block lapeer20m Everything Else | General Skoolie Discussions 7 04-13-2005 12:32 PM
