03-24-2012, 11:09 PM
Coachwork: Wayne Lifeguard
Chassis: Navistar International
Engine: 7.3 Power Stroker Diesel
Rated Cap: 24
Monitoring Fuel Consumption/Mileage
Hello,
Has anyone found any devices that will allow you to monitor fuel consumption/mileage in real time? There are a number of devices like ScanGuage in various forms for cars and light trucks, do any of these work for diesel buses?
Ed
03-24-2012, 11:20 PM
Engine: 3208 na boat anchor
Re: Monitoring Fuel Consumption/Mileage
Not something I really want to know. Dollars per mile might work for me, though.
03-25-2012, 09:10 AM
Rated Cap: 89
Doesn't some of the GPS devices do that... the pricier ones?
I have that ability on my Jeep. It's kinda worthless to me. The overall MPG is more useable.
03-25-2012, 09:45 AM
You would need a device to measure fuel flow, in addition to measuring distance traveled, for a GPS to give you mpg. Someone, more than likely, makes a GPS unit that can accomplish that, but I would imagine it's pricey.
03-25-2012, 09:59 AM
Just toss the magellen in the tank...
03-29-2012, 04:25 PM
Originally Posted by Pied Typer
I still do it the old fashioned way, stop at the gas station fill up / top off the tank then divide the number of miles I traveled since the last fill-up by the number of gallons I had to put in the tank... Viola lack of MPG!
Fixed it for you
06-23-2012, 03:07 PM
Moderator
Engine: DT408, AT545
Rated Cap: 23 500 gvw
I think you can only do something like that with electronic fuel injection. If your system is mechanical, I'm not sure that it is possible.
07-02-2012, 09:19 AM
Rated Cap: 24
The goal would be to monitor the MPG variations as I am driving so that I could learn to modify my driving habits real time to get better diesel mileage.
07-05-2012, 10:40 PM
I have a scandgauge works great, still trying to figure some things out, but it works well, tell real time, monitors fuel flow, mpg av mpg as well all your gauges are there to. it will tell you your cost per trip if you want to know. i think its worth it, figured out my best speed is about 92-94 kms per hour, average 9 us gals per mile. also learned that my cooling van comes on at 211 deg and shuts down204 deg ever time. may not seem to interesting, but if you start climing around 214deg you know u maybe starting to have a problem, other info things like turbo boost,oil press. etc gooogle it
07-06-2012, 12:39 AM
Chassis: All American RE
Any idea what year they started running OBD2 on the school buses? Just curious.
My bus is all mechanical so the only on board diagnostics I have is between my ears. Needless to say, a scanguage would be cool.
Ryan
Bluebird All American RE: Great White Buffalo (gone but not forgotten)
Our build thread: viewtopic.php?f=9&t=10065
07-06-2012, 08:18 AM
In cars they started in 1996. I would think it would be close with buses, in heavy trucks the call it j1208 or some thing like that not OBD2. (same thing) so you have to a scandgauge for diesel the connetion is round, just plug in and your ready
gbsteart
07-06-2012, 09:57 AM
gbsteart
Ya I'm familiar with it in autos but had no idea they called it something else in heavy trucks. And a different shaped plug to boot. Learn something new everyday. Thanks.
Ryan
07-06-2012, 10:07 AM
And try buying one of the newer truck computers... neighbor has one just sitting that needs a computer.. you can almost buy another tractor for what the computer costs...
07-06-2012, 11:24 AM
Just to add another layer of confusion--my 2005 Isuzu TD has the same computer diagnostic link as found on '96 and newer cars. Same plug and with the proper key card can be read with a standard "Snap-on" scanner. Go figure!?!
07-06-2012, 08:35 PM
Rated Cap: 79 at Birth
The bus I'm driving is a 1976 Crown with a Detroit Diesel 6-71 inline. I have found that when I'm on flat ground, it is a constant 10mpg no matter how I drive it. Go over some mountains and it's 9mpg. Nothing much seems to change that. It is what it is and most diesel engines with the load we are carrying aren't going to change much. Computer monitoring is going to be a nice touch, but in the end, it's not going to do much better for the vehicle and size and weight.
