Old 07-16-2018, 09:53 PM   #1
Atridox's Avatar
Engine: Gasoline
Mounting flag pole to roof
I am trying to figure out a way to mount a few flag poles to the ROOF of my bus. I am searching for mounting hardware which can attach to the sloping side of the roof. I do not want to use the flag pole drive over tire mount. Any help would be greatly appreciated.
Atridox is offline   Reply With Quote
Old 07-16-2018, 10:19 PM   #2
plfking's Avatar
Rated Cap: 34
Are you sure you want to drill holes in your roof? I'd probably mount the hardware to the window pillars instead.....less chance of leaks.
Don
The Busted Flush
Old 07-17-2018, 06:39 AM   #3
brokedown's Avatar
Drilling holes in the roof is one of my least favorite things to do.. But I do it, I just do it carefully. You need to add a sealer to the hole and drive your screw or bolt or whatever into the sealer to get a good seal, and I smear some on top when I'm done too. The last hole I cut was with a 1 1/4 hole saw which i did not enjoy at all but I sealed it up tight.
I have had really good success with stainless steel self tapping screws like Teks brand at Lowes. Make sure to get less than 2 inch length or you'll poke through the inner skin too. I use #8 and #10 sizes depending on what I'm mounting.
Old 07-17-2018, 08:37 AM   #4
somewhereinusa's Avatar
Chassis: AARE
Engine: 3116 Cat 250hp
I didn't mount mine to the roof, I made brackets and bolted them to the front. I have a 20 foot flag pole and it sits on the front bumper. I also have a light so I can can properly fly the flag at night.
Detail of bracket.
Old 07-17-2018, 09:04 AM   #5
Chassis: All American RE
Engine: 8.3TA
Had not thought about my amateur radio antennas yet, but that will work for that also. Thanks!
GaryC
Gustav is offline   Reply With Quote
