Old 09-04-2010, 10:58 AM   #1
opus's Avatar
Chassis: All-American R/E
Mounting generator
Looking for some ideas on hanging a generator off the back bumper. Easy task but for being a R/E bus I need some design ideas.
Old 09-04-2010, 12:09 PM   #2
opus's Avatar
Re: Mounting generator
I need all the belly storage that I have. Theft isnt an issue, rear ended would be. Its either that or the front bumper. I dont want it underneath, for a multitude of reasons. Chances are it would be running going down the road at times, as well.
Old 09-04-2010, 02:33 PM   #3
RevBill's Avatar
Coachwork: - Still Shopping -
Chassis: - Going Medium/Large -
Engine: - DT466 Desired -
I might have missed the info on what size genset you are going to use .. but if it's a portable one that won't weigh a ton (or so) you could mount it on a hitch/receiver .. easily removed for maintenance and can also be set away from the bus when you are parked and don't want to listen to it )or need some space for exhaust fumes) .. use twist-lock connectors to keep anything from falling apart while using when going down the road or at "home" ..
.. if you ever change over to a trailer you can put it on the tongue in a separate box/housing on the trailer ..
.. keeps you pretty modular and portable until you come up with a final setup .. and it's a pretty affordable way to go as well ..
Chance favors the prepared mind. - L Pasteur
Luck is the residue of good planning. - B. Rickey
Travel is fatal to prejudice, bigotry, and narrow-mindedness ... - M. Twain
RevBill is offline   Reply With Quote
Old 09-04-2010, 04:54 PM   #4
opus's Avatar
Its an Onan BFA 4.0. Weights less than 250#, add some for a battery and fuel tank. I was thinking 2 receiver hitches, with one having a pivot on it so it would swing out of the way for when I want to get into the engine compartment.
Old 09-11-2010, 10:33 AM   #5
lornaschinske's Avatar
Rated Cap: 89
Sounds like you already have an idea that would work. Lock that sucker down. It's amazing how many generators will just vanish!
We are thinking of building a hauler for our future scooter. We want to do a dual "receiver hitch" on the front of the bus. We built the rear receiver so it can't be too much different (just twice the work! )
My biggest complaint about my Hitchhaul is that it "wobbles" unless the load is balanced. A dual receiver would fix that.
Fulltime since 2006
Old 09-11-2010, 10:39 AM   #6
opus's Avatar
The issue is going to be making it so I can open the engine compartment. Havent quite figured that one out yet.
mounting generator inside bus? collincountycab Electrical, Charging and Solar 11 10-11-2012 09:53 PM
Mounting portable generator under bus jkindt Conversion General Discussions 1 02-16-2010 01:43 AM
Generator mounting Diesel Dan Conversion General Discussions 2 01-27-2010 06:47 PM
Generator mounting eggman Conversion General Discussions 18 02-28-2007 09:39 AM
Mounting generator under bus has anyone done this and how. heath692 Conversion General Discussions 3 04-25-2005 10:34 PM
