Old 02-15-2010, 11:52 PM   #1
jkindt's Avatar
Year: 1981
Chassis: Ford B-600
Engine: Ford 370 Propane
Rated Cap: 48
Mounting portable generator under bus
What is the difference between the generators that are mounted underneath the bus and a portable generator? Is it possible to mount a portable generator? Other than extending the exhaust to exit properly, what else is different? I found a great deal on a propane powered generator, but it is a 'portable' unit designed to run off of a standard 20lb LP tank. I would like to be able to run it off of my existing LP fuel tank that the bus runs off of, and I don't really want to pull it out just to fire it up if possible.
Old 02-16-2010, 01:43 AM   #2
jkindt's Avatar
Year: 1981
Chassis: Ford B-600
Rated Cap: 48
Re: Mounting portable generator under bus
The previous owners have a Champion generator that they used with this bus. They just dragged it out behind the bus and ran a heavy extension cord to whatever they needed powered. It is not the quietest, but with proper mounting and sound proofing techniques, I bet it would be quieter mounted under the bus.
How to: Build a portable generator enclosure. Stuff Conversion Tutorials and How-to's 3 08-09-2011 10:34 AM
Mounting generator opus Electrical, Charging and Solar 5 09-11-2010 10:39 AM
RV or portable generator? BUSBOZO Conversion General Discussions 5 07-11-2010 04:22 PM
Can I mount a portable generator on the back of my bus? odyssess Conversion General Discussions 8 08-23-2007 06:36 PM
Portable Generator Muffler? Steve Everything Else | General Skoolie Discussions 2 04-14-2004 03:14 PM
