Old 12-08-2018, 12:43 AM   #1
T-Bolt's Avatar
Engine: DT530
MPG Expectations
What kind of MPG can I expect from a DT530 with an unlocked 3060?
How much will towing a flatbed with a van on it hurt me?
T-Bolt is offline   Reply With Quote
Old 12-10-2018, 08:34 PM   #2
david.dgeorge07's Avatar
Chassis: Thomas
Engine: CAT 3126
Gearing and cruising speed will matter a lot. But it is hard to guess wrong for a full size bus if you guess 6-9.
My Build Thread:
http://www.skoolie.net/forums/f11/4-...ner-18205.html
Old 12-11-2018, 09:31 AM   #3
alot has to do with gearing and terrain.. you DONT want to lug that DT.. ideally you'd like your highway cruise 1700-1900 on that engine in 6th.. and then a downshift to 5 takes it to that 1900-2100 range... lower you'll lug it and kill your MPGs.. too high (above 2300 you make lots of heat and less power) ..
weight plays a part for sure esp if you are climbing and descending grades..
I think 6-9 with your trailer is a good estimate
Old 12-11-2018, 09:58 AM   #4
T-Bolt's Avatar
Engine: DT530
Bummer. I was wanting 20. Jk
Old 12-11-2018, 11:08 AM   #5
I got 20 once in my red bus.. I was heading to florida right near a massive cold front... the north winds were gusting to 35 and i was headed south.. lol..
Old 12-11-2018, 11:12 AM   #6
My Bluebird with the 8.3 and 3060 gets 9-10.5mpg
Old 12-11-2018, 02:49 PM   #7
T-Bolt's Avatar
Engine: DT530
I have a 4.83 gears. No clue if that's good or not.
Old 12-11-2018, 03:07 PM   #8
With OD and full size tires that's a nice ratio.
Roll Your Own Build Thread
Old 12-11-2018, 03:17 PM   #9
Agreed. I have 5.29's and, at times, I wish for 6th gear or a slightly taller rear.
Without 6th opened up, I think 4.83 is a great highway gearing.
If you are able to get 6th unlocked, 4.83 may be a little tall. In my very humble opinion..... We don't need to go 85mph in our buses....
Old 12-11-2018, 04:49 PM   #10
T-Bolt's Avatar
Engine: DT530
6th is unlocked already. Originally ordered as a sports bus so set up for the highway.
Old 12-11-2018, 06:18 PM   #11
HappyInTN's Avatar
Chassis: Genesis
Rated Cap: 84lug
my 15 window dt466 (7.6) puller gets a lil over 11 mpg
Note: I am no longer selling skoolie insurance. I sold my agency and am traveling N. America full time with my family. Wish us luck!
Serenity Bus Project: OUR NEW EBOOK. ITS A HOW-TO GUIDE. PLEASE CHECK IT OUT! --> https://www.serenitybusproject.com/store/p1/So-Your-Dream-Of-Owning-A-Skoolie.html
HappyInTN is offline   Reply With Quote
Old 12-12-2018, 06:18 AM   #12
JDOnTheGo's Avatar
Coachwork: MCI
Chassis: 102 EL3
Engine: DD 60
I've spent a lot of time getting the average for my coach. I admit that it varies a little but generally comes out to 5,001 MPG.
I know...
This is much better than most people get and I'm not sure what they are doing wrong.
For me, the fuel consumption reported by my gauge is usually about 3 MPG climbing a hill. I then record the consumption going down the hill - usually 9999.9 MPG. The math is then pretty simple, add the two data points and divide by the number of data points (2). So, 9999.9 + 3 = 10,002.9 / 2 = 5001.45 MPG.
I feel very good about this number as I am pushing around about 46,000 lbs with a Detroit Diesel 60.
JD - Full timer out west
My Adventures & Build
Old 12-12-2018, 07:06 AM   #13
MPGs sre very much speed dependent.. i think we all should post our MPGs with our cruising speed.. I just did a 1200 mile road trip and ran 65 up.. (into a decent headwind) and ran 67 going back (very little wind).. the weather is cold so I had a lot of idle time. and I still got just about 11.
Old 12-12-2018, 08:25 AM   #14
T-Bolt's Avatar
Engine: DT530
I know...
Lol. Seriously it actually got a laugh from my wife.
Old 12-12-2018, 08:33 AM   #15
T-Bolt's Avatar
Engine: DT530
Agreed but bus details should be included. (Engine, trans, OD, length, towing...)
This is the number one question people ask when they learn I have a bus. "You own a bus? That must get terrible mileage." With a family of 8 we have driven our van all over the country and get around 17mpg so relatively speaking the bus is really efficient.
Old 12-12-2018, 11:37 AM   #16
in my case my bus is a 6 window bluebird on a 3800 Chassis..(23.5 feet) GVWR is 17000 (I havent got actual axle weight).. engine - 190HP T-444E tuned up to 230HP. Trans - 6 speed allison 1000. (1550 RPM at 65 MPH 6th gear). (1750-1800 RPM at 65 MPH 5th gear {it likes this best})
Old 12-13-2018, 08:57 AM   #17
JDOnTheGo's Avatar
Coachwork: MCI
Chassis: 102 EL3
Engine: DD 60
... so relatively speaking the bus is really efficient.
I rarely use non-truck stops for fuel but once at a 'gas station', someone made a comment (that sounded a little snide) about the horrible mileage 'that thing' must get. I simply asked them; "What kind of mileage does your home get??"
Old 12-13-2018, 09:56 AM   #18
then you ask them.. "How much FUN per galloin do you get in that corolla?"
Old 12-13-2018, 01:46 PM   #19
Hey JD,
What kind of mileage do you really get?
I managed 7.25 OMG pretty consistently running cross country in my Eagle with 8v71 & HT740.
Old 12-16-2018, 03:52 AM   #20
concrete's Avatar
Coachwork: American Fire & Rescue
Chassis: IH 4900
Engine: DT466 250hp P-pump
T-bolt, what year/size is your bus?
concrete is offline   Reply With Quote
