Old 07-16-2013, 01:17 PM   #1
Chassis: Tc2000
Engine: 5.9 Cummings turbo diesel
My first oil change
Up until now, I have taken my 97 BB TC2000 to a heavy truck shop for service. I am very mechanically inclined, I just haven't had the time to tackle this myself yet. Until now. Any words of advice, or other things I should service during my oil change? TIA!
Great nations rise and fall. The people go from bondage to spiritual truth, to great courage, to liberty, to abundance, to selfishness, to complacency, to apathy, to dependence, and back again to bondage.
kc_4_jc is offline   Reply With Quote
Old 07-16-2013, 01:36 PM   #2
Engine: 466DT
Re: My first oil change
Make sure you have a big catch container I was expecting mine to be like about 5 gallons, but if I remember right, it was closer to 7. Lucky I had another container not two far away empty, and didn't let the plug fall to the bottom of the catch container.
Hvbuzz is offline   Reply With Quote
Old 07-16-2013, 01:38 PM   #3
wmkbailey's Avatar
Engine: 3126
Looking at the maintenance records for my bus. In March they did an oil change and it took 32 quarts, or 8 gallons. That is a lot of oil.
William
http://thejourneyvisvi.com/
My Conversion Thread:
viewtopic.php?f=9&t=464989
Old 07-16-2013, 01:40 PM   #4
roach711's Avatar
Rated Cap: 19
If your oil filters are anything like mine, they're big honkin' things and quite hot and heavy when full of oil. I first make sure I can turn the filter (sometimes they're almost welded on) then I snug it back up and use an ice pick and hammer to puncture the bottom of the filter. Once all the oil has drained out the filter is much cooler and lighter and ready for the trash.
I put a Fumoto Oil Drain Valve on mine. I put an empty milk jug under the valve, open the valve and fill the jug directly. It's really convenient, especially since mine holds 15 quarts and my drain pans only hold 5.
Since you're under there already, that's a good time to lube up the front end if it's been a while.
Other stuff to look for: Brake, trans and oil leaks; uneven tire wear, rusty oil & trans pans or a raccoon hiding up on the rear axle.
The Roach Motel
Old 07-16-2013, 05:05 PM   #5
opus's Avatar
Chassis: All-American R/E
Go here: http://www.blackstone-labs.com/ Ask them to send you a sample bottle and send them an oil sample. For $25 you will save your self a lot of wondering what the engine is like.
Old 07-16-2013, 06:43 PM   #6
bapos's Avatar
Chassis: 2001 International RE
I would make sure you wear old clothes. Nothing like oil running down your arm on to a shirt that is not a "working on car shirt?" I would also wear either an old pair of gloves or even a set of nitrile gloves? It helps from getting your hands super dirty. If your filter screws in vertically .... you may want to prefill it either half way full or part of the way. It just helps with dry starts. If its horizontally then don't worry about it. Its more of a pain in the azz than its worth. I would also look for leaks... they are not hard to find cause they are black and will be coated with dirt.
Its not hard. As others said MAKE SURE YOU HAVE A BIG ENOUGH CONTAINER TO CATCH THE OIL. There is nothing worse than about to run over and nothing else to put it in to.
You can do it. Nothing major.
Old 07-16-2013, 07:29 PM   #7
Listen to the warnings!
It really does suck when your under there smiling at the fruits of you labor...then you realize...crap!! It ain't goning to fit!!
Okay; first panic!
Then cover hole with finger,thumb or hand (do NOT stick you finger IN the hole...you are not tom thumb)
At this point you yelling and hitting things to get someones attention.....alas:
You are alone!
You look around and spy a vessel for the buses life blood!!
Sweet that's cool.....
I can guarantee this:
You can not roll out, retrieve said vessel....(some people call it a taco)
Roll back under and not make a mess....
Make sure you can cantain 20 qts+ of liquid....
Oh!....have fun and get someone other than you to take funny pictures!
Good luck
Old 07-16-2013, 09:05 PM   #8
I don't envy you changing the oil--but you're probably better at it than me and won't have a mess. What oil brand/type do you plan to use to refill?
Old 07-17-2013, 08:18 PM   #9
roach711's Avatar
Rated Cap: 19
Check out the Fumoto drain valves. No more dropped drain plugs, no need to steal the neighbor's kiddy pool to get enough drain pan capacity and you can drain into gallon milk jugs one gallon at a time. Much cleaner and no oil slopping out of the pan when you pull it out from under the bus. The only negative is that it replaces my stock magnetic drain plug.
http://www.qwikvalve.com/?gclid=CJDC8LX ... MgodyiIAug
The Roach Motel
Old 07-29-2013, 08:29 PM   #10
Coachwork: Ward Genesis
Engine: DT466/MT643
It's a 5.9 Cummins, so it probably uses about 4 gallons of oil. (My buddy's Bird has the same motor & uses 16 quarts.) It should use a standard oil filter...looking up a same-year diesel Ram should get you the right one. Oil will be 15W-40, whatever you can get the cheapest will work.
Jarlaxle
Rear axle gear ratio. To change or not to change. slade Conversion General Discussions 15 04-24-2017 02:33 PM
Bus to RV title change in VA - anyone successful? dgorila1 Titles, Insurance, Registration and Money Matters 0 08-02-2011 09:02 PM
I-77 elavation change???? CVanDamme Everything Else | General Skoolie Discussions 12 11-17-2009 07:59 PM
how to change shocks? adamanderr Conversion General Discussions 6 12-12-2008 07:27 PM
The observatory *Name change! TikiBus Skoolie Conversion Projects 8 11-20-2008 03:53 PM
