Old 07-22-2010, 09:57 PM   #1
opus's Avatar
Chassis: All-American R/E
My floor thoughts
Trying to think this all out before I actually do it. Pull the old rubber/wood, clean and paint. Next would be red rosin paper then 1 x 2's window to window. Pink board will go between them, then a vapor barrier and then 1/2 or 3/4 plywood, attached to the 1x2's. There will be a gap along the walls and back, allowing movement, etc.
Make sense or am I off somewhere?
Old 07-23-2010, 10:04 AM   #2
opus's Avatar
Re: My floor thoughts
What size "floor joists" would you recommend? I was thinking of ripping 2 x 4's.
3/4" plywood...fine.
Old 07-23-2010, 12:50 PM   #3
Year: 55
Coachwork: Ford
I ripped 2" x 4" s and drilled pilot holes to keep from spliting. I used the triple coated deck screws with 6 lobe heads. The are strong and drive great.
bodaver32 is offline   Reply With Quote
Old 07-24-2010, 09:18 AM   #4
opus's Avatar
The reason I want floor joists is that after a while I am afraid the insulation will break down and compress in high traffic areas. I wont be fastening anything to the main bus floor.
Old 07-24-2010, 09:32 AM   #5
Chassis: Ford E350
Engine: 7.3L Turbo Diesel
Rated Cap: 19
I would say no need to put down floor joists. The plywood could be fastened straight through the insulation and to the sheet metal floor. Thats how I did it. The plywood will distribute weight and wont damage the insulation. Do what you are comfortable with though.
zman18 is offline   Reply With Quote
Floor Plans B4 Roof-raise on Monday! Let me know thoughts! Alexlorraine01 Skoolie Conversion Projects 8 08-06-2014 07:33 AM
Crappy thoughts? Jarlaxle Plumbing, Water and Waste 23 07-27-2010 12:16 PM
THOUGHTS ON A DIFFERENT SKOOLIE BUSFREAK08 Skoolie Conversion Projects 3 02-15-2010 06:43 PM
Floor Plan, Electrical and Plumbing layout - thoughts? Wildcat Conversion General Discussions 6 09-09-2009 07:12 PM
91 All American, FE, any thoughts? BBTC2K Everything Else | General Skoolie Discussions 15 10-26-2007 05:17 PM
