Old 01-10-2013, 05:24 PM   #1
Engine: Ford B600 6.6 TurboDiesel
Rated Cap: 32
My heat doesnt seem to be working
Hi,
I have a 93 ford school bus. It doesnt seem like the heat is working. I notice that there are two hoses coming thru the firewall into the bus. One of the hoses has a valve on it. Its turned all the way open but I stil have no heat. It seems to me like the heat is created with the coolant in the radiator and it is supposed to go thru these hoses. Can anyone help?
bbeenn88 is offline   Reply With Quote
Old 01-10-2013, 05:49 PM   #2
GreyEagle's Avatar
Re: My heat doesnt seem to be working
Look under the hood for any additional cut offs......... double check to be sure the hoses are hooked up in the engine compartment......
GreyEagle
Roll - On...
GreyEagle is offline   Reply With Quote
Old 01-10-2013, 07:02 PM   #3
You should have atleast 2 valves,most look like garden hose connections...clockwise closes them and turning to the left opens them.
Old 01-10-2013, 09:56 PM   #4
travelinwithus's Avatar
I would think you would be able to "follow" the heat also. When the bus is warmed up just feel the hoses and see if any are warm and if some are keep following the hoses and feeling until you find where they begin loosing temp.
travelinwithus is offline   Reply With Quote
Old 01-11-2013, 08:30 AM   #5
Diesel Dan's Avatar
Engine: DT466/AT545
And of course there are electric blower motors that circulate the heat around the bus. Are your motors just blowing cold air because there is no hot water coming in? Or do the blowers not work either?
Gallery:
Conversion Thread:
viewtopic.php?t=4959
Old 01-12-2013, 07:33 PM   #6
bapos's Avatar
Chassis: International Amtran RE
Engine: DT466E/MD3060
Follow the path of the hoses. Feel what is hot and what is not. You should be able to find your problem.... in theory?
Old 01-14-2013, 05:15 PM   #7
Engine: DTA360
Rated Cap: 16
Mine has two valves, one in the dog house(engine compartment) and one behind the front bumper... Both have to be open to circulate...
dirtygoat is offline   Reply With Quote
When not working on the Skoolie... browncrown Everything Else | General Skoolie Discussions 4 01-21-2013 07:06 PM
gauges not working headin2MT Conversion General Discussions 3 02-08-2012 01:50 PM
Working on the road 5k00li3n00b Everything Else | General Skoolie Discussions 10 01-19-2012 09:11 AM
STILL working on my bus! KC10Chief Conversion General Discussions 1 08-23-2008 12:46 AM
The master cylinder that doesnt exist! - GMC 1 3/4" bor Steve Everything Else | General Skoolie Discussions 9 11-27-2006 06:46 PM
