Old 11-21-2006, 02:10 AM   #1
My Kingdom for a comfortable Toilet
Hello all.
Please forgive me if this has been covered before. I have a Bus project and one of the things that will be in it is a toilet. Now the Idea of doing my duty in a coffee can dose not appeal to me. My choice of toilet would be an elongated bowl with some water in it. I'm willing to put in a large black water tank. Any products out there that would mimic the workings of a regular toilet? I am familar with microfor toilets and emacerating toilets; would this be the best choice? Open to any serious ideas.
Williams Family, Proud owners of a $200 1985 GMC Blue Bird (A work in progress).
SamW is offline   Reply With Quote
Old 11-21-2006, 08:26 PM   #2
Les Lampman's Avatar
Heya Sam,
Well, I wholeheartedly agree!
A 'typical' RV toilet is a gravity thing; it's intended to sit over the top of the wate tank underneath. There's typically a foot valve at the base of the toilet; rasing that will put some water in the tank for use, pressing down on it will open the slider valve and allow the waste to fall into the black water tank below.
These toilets are available from (relatively) inexpensive all-plastic units to very expensive all china and super fancy units. I think most folks will find the toilets that are listed as having a "household" sized bowl more comfortable. I got a Thetford Auqa-Magic Aurora with a china bowl because I thought it would be easy to keep clean and might not stain as easily as a plastic unit. I don't remember precisly but it was something just under $200 or so. You can get something like a Valterra "La Toilette" for under (or around) $'s all plastic. You can get a Thetford Auqua-Magic V which it sized much like a home toilet and is typically operated with a hand valve for maybe $125 or so.
Marine toilets, on the other hand, are not typically situated over the waste tank (that would be under the boat!) and instead rely on pumping the waste from the toilet to the holding tank. Some are manual and operated with a hand pump (pumping up and down, or back and forth), others are electric and mimic the manual motion or use a macerator pump to chew up the waste into small bits and also pump it to the holding tank. These also come in "compact" and "full size" models to accommodate different space requirements. And, they also range from low price (manual, compact, plastic model) to absurdly expensive.
The advantage of the marine toilet is that it can pump the waste to a remote location when siting the toilet over the tank won't work and with the electric models flushing is just a push of the button. The downside is they're finicky...a wrong "something" (such as a sanitary napkin) will plug it up big time and clearing the problem is not a fun task whatsoever. They also have components that require periodic maintenance.
The advantage of the RV toilet is that it's simple and all but impossible to plug up. Even with the water line broken or no power available it can be used; assuming you have some water in jugs or a bucket you can dump some in the bowl, use it, and flush it by stepping on the manual slide valve. Simple is good! The disadvantage is that it needs to be over the holding tank (or close enough that a pipe doesn't have much of a horizontal run).
Finding one that's comfortable, I'm afraid, is a matter of personal feel. Just as in home toilets bowls come in all shapes and sizes as do the toilet seats. One size doesn not fit all so I think you'll just have to look for "full sized" or "household" sized units and make your best judgement. And that, as they say, is the bottom line (I'm sorry...I just couldn't resist! )
Les Lampman
1982 Thomas Saf-T-Liner Pusher "Illusion" Gallery
Illusion's SmugMug site
Les Lampman is offline   Reply With Quote
Old 11-22-2006, 07:45 AM   #3
I picked up the same toilet Les did for our Bus …also got the riser they make to get the toilet up to a better height.
It’s a pretty good toilet and I can say from experience Porcelain bowls are where its at . “Icky Things’ tend to stick to the plastic models. So you use more water to clean the bowl out than you would if you had a china toilet.
For our trailer we chose Sealands China toilet …it’s taller than the Aurora and uses less water to flush itself.
Because the trailer will have big bays , I’m going for a dual-system where you can either dump into a Black water tank or a composting system.
Speaking of our trailer project, I’m pretty excited. The welder is going to start putting our frame together next week …..
Our bus is on hold till the weather gets better. We’re having one storm after another, dumping unusual amounts of snow on us here in Sitka……its amazing and strange for sure.
By the way you can pump out a regular RV style holding tank like they do on boats , you just use a macerator pump to do this.
Are you questioning my Aaa-thoritttyy ?
soused moose is offline   Reply With Quote
Old 11-22-2006, 01:45 PM   #4
Thank you both, I think that I can find a suitable toilet from from one of those vendors. Porcelain, elongated, and the ability to make ugly things go away reliably, is all man can ask for.
Old 11-22-2006, 08:02 PM   #5
Elliot Naess's Avatar
Engine: 5,9 Cummins
I went for the Rolls Royce of RV toilets; Thetford Aria. Comes in "Classic" with foot pedal flush, and a fancy one with 12 Volt electric flush valve. It's just as tall and comfortable as the one in my house. And yes, a hard working man deserves a comforable commode!
Old 11-22-2006, 09:29 PM   #6
GoneCamping's Avatar
There are different things out there, but if you want a nice China Bowl at a reasonable price then TRY THIS ONE
...Your home has brake lights
1994 Jeep Grand Cherokee
Chesapeake, Virginia
GoneCamping is offline   Reply With Quote
Composting Toilet cdemaris Conversion General Discussions 4 02-09-2011 09:20 PM
toilet options chaos Skoolie Conversion Projects 2 03-10-2010 06:57 AM
Toilet special needs Seeria Conversion General Discussions 5 11-05-2009 07:34 PM
Toilet GoneCamping Conversion General Discussions 1 11-14-2008 06:38 PM
Toilet...which one and why? crazycal Everything Else | General Skoolie Discussions 5 07-10-2008 11:19 AM
Copyright ©2000 - 2016, vBulletin Solutions, Inc.
