Old 04-03-2011, 08:31 PM   #1
lornaschinske's Avatar
Rated Cap: 89
Re: Mysterious Floor Hole
Only hole in our floor (also covered by a metal plate that is screwed down) is the access hole to the top of the fuel tank. Gives access to the fuel level sending unit.
Fulltime since 2006
Old 04-03-2011, 10:08 PM   #2
somewhereinusa's Avatar
Chassis: AARE
Engine: 3116 Cat 250hp
Fuel sending unit is what tells how much fuel you have. If there is an access hole, you won't be able to get at it any other way other than removing the fuel tank. If that is what it is you haven't gotten everything off yet. You should be able to see the top of the tank. Sending unit is usually round with some screws holding it to tank with one wire going to it.
Old 04-04-2011, 12:00 AM   #3
Stuff's Avatar
yup looks like the fuel level sending unit to me.
Old 04-04-2011, 11:38 AM   #4
Rated Cap: 89
Make sure you can access this hole later. I've already pulled our brass float out of the fuel tank and soldered a hole closed in it (now it works). Ours was pretty filthy too (I used an old paint brush that we use as a dust brush to clean off the top of the tank. Unfortunately, a base cabinet in the galley will cover our access panel so I have to remember to make the cabinet to where I can pull it out at a later date if need be. The cabinet is my 10" wide can rotator so the bottom of the cabinet will be inaccessible.
Fulltime since 2006
Old 04-04-2011, 02:01 PM   #5
Diesel Dan's Avatar
Engine: DT466/AT545
In addition to the fuel level sender, it looks like your fuel supply and return hoses are also accessible through this access hole. If you end up with a clogged tank screen (if so equipped) or a hose gets old and goes bad, or any number of other tank access scenarios, you will be glad you left that access hole accessible. Check out the size of the tank mounting framework, not to mention the size and weight of the tank itself! You do NOT want to be forced to remove and reinstall that thing!
Gallery:
Conversion Thread:
viewtopic.php?t=4959
Why is there a hole in the bottom of our hot water tank? freakn Conversion General Discussions 6 09-08-2011 02:58 PM
Sealing 4"x4" hole in roof? VictorWhitacre Conversion General Discussions 5 06-16-2010 06:55 PM
Has anyone Filled in a window hole on a Fiberglass Bus? Stuff Short-Bus Conversion Projects 1 05-26-2010 10:04 AM
Filling in a hole in the floor jkindt Conversion General Discussions 2 05-09-2010 10:05 AM
Hole in Floor for Storage. Coma Conversion General Discussions 6 07-21-2006 10:20 AM
