Old 06-14-2009, 08:41 PM   #1
Re: Narrowed Down my Bus Choice - Need advice
If it were me, I'd take my chances on the private seller for half the price, assuming that the buses really are quite similar (age, condition, mileage, known issues, etc.). Having the seats already out is a bonus. I wouldn't put much faith in a dealer's "warranty", because such things often turn out to be worthless when you really need them. I'd have an experienced mechanic look over the cheaper bus, and if he found no red flags, I'd take it home and use the extra $2K to start making it pretty.
zamfir is offline   Reply With Quote
Old 06-14-2009, 08:46 PM   #2
recycler's Avatar
Year: 86
Coachwork: Thomas saf-t-liner
Rated Cap: 40
Private seller is giving you a better deal in my uninformed opinion. 2g's is a perfect value based price. See if he will let you get it checked out before buying. Good luck with your choice.
recycler is offline   Reply With Quote
Old 06-17-2009, 04:27 PM   #3
NewSkewlHauler's Avatar
Engine: 8.2L Detroit N/A, Allison
I have talked to a couple of guys that work there about their buses...very friendly and seem to know their stuff. I've stopped by their lot and checked to see what they have...mostly good stuff, but not exactly what I'm looking for. I'm not sure if that helps, but I've had pleasant dealings with them.
Ben.
NewSkewlHauler is offline   Reply With Quote
Old 06-30-2009, 11:50 PM   #4
Year: 2012
Coachwork: Need bus-as-home over RV
Chassis: still looking
Professional oil analysis!
I don't claim to be an expert, but my father was a fleet mechanic and i've heard other mechanics tell me an oil analysis of engine oil and transmission oil will pretty much tell you anything hidden like impending failure or someone putting in some "trick additive" to cover up some problem or whatever. I couldn't tell you where to go or what it would cost but definately less than a replacement engine, transmission, or a tow charge from nowhere. To avoid someone snatching it you might put money down on the bus (with a signed agreement) just awaiting the results of the oil test to verify it's in good shape.
That plus a trained mechanic looking for obvious problems like seriously damaged brake lines or a differential leak, I mean a $2000 bus that becomes a nightmare costing even more to haul somewhere to get rid of isn't a deal at all. Not to be negative, just cautious. There's no true guarantee on the $4k bus either afterall, even if they fixed something would they reimburse a tow? An untrained eye probably would even miss broken springs if not pointed out. :P
At the most basic if you dont get professional oil analysis you can also look for obvious leaks under the bus. Normal road dirt and such should be present - if it looks "clean" it was probably cleaned, to hide an oil leak. Same with the engine oil - it should be used, a fresh oil change might indicate someone HIDING something from potential oil analysis and such. Sniff the transmission fluid in an automatic - if it has a burned smell or looks between dark red and brown that means a dying tranny, instead it should look pink or light red.
There should be online, internet, library and other guides about "how to buy a car" which still applies at least as much to a bus, some of the examples are given above.
Service histories are a plus - i'd spend more on a bus with full verifyable service histories and alot more miles than a "low mile" special where the previous 4 owners did who knows what to it, they could have run it low on oil or not changed oil or tried to pull stumps with it.
The above is what i'm planning to do when I narrow things down myself.
nearhomeless is offline   Reply With Quote
Wheel choice Ponyracer Conversion General Discussions 13 10-08-2014 10:47 AM
Window choice pros and cons bapos Conversion General Discussions 19 07-24-2012 11:53 AM
366 BB Carb Choice Gyva GM | Chevrolet Drivetrain 7 09-19-2010 08:57 AM
Bus Choice Vern1 Conversion General Discussions 5 06-13-2009 12:04 PM
It Seems a TC 2000 is a good choice? britishroamer Classifieds | Buy, Sell, Swap 4 11-28-2007 06:36 AM
