Old 02-23-2010, 07:03 PM   #1
Coachwork: Ward Genesis
Engine: DT466/MT643
Re: NEED Advice: Should I buy this bus??
Nobody is sure what year it is? Does it have a title? Can you register it?
Jarlaxle
Old 02-23-2010, 10:17 PM   #2
Year: 1978
Coachwork: thomas
Chassis: ford
Engine: 406 Ford
Rated Cap: 25
I think that if money is no object, then go for it if you like it- it's a cool old bus, but if money isn't in abundant supply, then you might wanna consider a bus that you can source the parts for easier. A bus that has been sitting for 5 years is definitely going to need some attention.
bus-ted is offline   Reply With Quote
Old 02-23-2010, 11:02 PM   #3
jkindt's Avatar
Year: 1981
Chassis: Ford B-600
Engine: Ford 370 Propane
Rated Cap: 48
I like the looks of that bus. The front end looks so much more 'modern' than it really is.
Old 02-23-2010, 11:25 PM   #4
timbuk's Avatar
Year: 1965
Coachwork: thomas
Chassis: chevy
Engine: 350
that bus looks like a well thought out coach conversion.Awning, gen,roof racks and ladders,etc.It was a nice bus for sure.Get a mechanic to look at it if you are interested.You can tell it was taken care of for sure.Maybe ask some qs at the coach site.I like it.
Old 02-24-2010, 06:35 AM   #5
dentedvw's Avatar
Coachwork: Thomas SafTLiner
Chassis: FE
Rated Cap: 60
Beautiful bus! Coaches like this were meant to go forever, as long as they are maintained. You really want to have a good look at the frame, especially around the rear and front wheels. Look at the supports that hold up the body. If they are in bad shape, it's probably done, spare parts for another bus. If they are solid, that's one point on it's side.
Someone else will know about the engine, I am a dolt when it comes to engines.
dentedvw is offline   Reply With Quote
Old 02-24-2010, 04:12 PM   #6
busdriver_phil's Avatar
Coachwork: AmTran RE
That's a great engine, the majority of transits of that vintage have the 6V71. Those engines can go for half a million miles between rebuilds if you take care of them. A small amount of oil leaking is normal for those.
As for speed, it depends how it was geared. I've driven transits that topped out in the low 50s, and others that made it up to 95 (for real, no exaggeration).
The conversion of Miss Euphegenia, a 1999 AmTran RE: https://www.skoolie.net/forum/viewtopic.php?f=9&t=5704
Old 02-24-2010, 06:45 PM   #7
Engine: DT466/MT643
Skoolies...seen one that topped out under 50, seen a couple that would top 80.
For coack and Flx stuff: www.busnut.com forum.
Jarlaxle
Advice newbiefamily Conversion General Discussions 11 03-29-2014 08:57 AM
Need advice please chev49 Conversion Tutorials and How-to's 2 07-14-2012 08:44 AM
Bus advice gbstewart Conversion General Discussions 5 02-01-2012 08:54 PM
New and Looking for Advice bm1253 Short-Bus Conversion Projects 12 04-18-2009 12:19 PM
Need advice concerning A/C Blackhorn Buses Conversion Tutorials and How-to's 2 12-17-2008 08:26 PM
