Old 04-15-2011, 08:59 PM   #1
Year: 89
Coachwork: thomas
Engine: 7.3 diesel
Need advise from the VETS
I have built a metal box to hold a onan and 4 batteries, I have had a hard time getting my welder over here to hang it. He is so wrapped up.Another welder told me to just bolt it to the cross members, all of em underneath. My question is will it hold? any advise is appreciated
see my conversion at https://www.skoolie.net/gallery/v/Skoolies/Putters+Bus/
putterspitt is offline   Reply With Quote
Old 04-16-2011, 09:52 AM   #2
Year: 89
Coachwork: thomas
Engine: 7.3 diesel
Re: Need advise from the VETS
I bought a sheet of steel for 86 bucks I believe, I cut it out with a skill saw, then had it tacked by a friend. Then a buddy welded it out for 20 bucks
its 22x66x18 I believe
Old 04-16-2011, 07:56 PM   #3
Year: 89
Coachwork: thomas
Engine: 7.3 diesel
for the life of me I cant remember, I did put 2 1 1/2 pieces of angle underneath it so the weight will be mostly on them, as I will attach them to the top supports by using angle as hangers, its not quite 1/8" though
Old 04-25-2011, 01:36 AM   #4
Engine: DTA360
Rated Cap: 16
I would bolt it... Bolts are easy to tighten if need be or replace for that matter... Welds crack... Even if you're a good welder, they can crack... Welding will also be a pain in the ass if you ever need to remove it...
BTW, I weld a lot of stuff...
dirtygoat is offline   Reply With Quote
Old 04-25-2011, 09:38 PM   #5
Year: 89
Coachwork: thomas
Engine: 7.3 diesel
drilling 36 holes is a pain in the ass also, lol thanks, I am gonna bolt it in,,,,,,,
Old 04-26-2011, 10:56 AM   #6
lornaschinske's Avatar
Rated Cap: 89
Put a little dab of E-6000 adhesive in the threads to keep the nut from unthreading from vibrations while going down the road. It's cheap and you can get the nut off again if/when you need to. Cheap alternative to a nylon insert nut as well.
Fulltime since 2006
Old 04-26-2011, 10:16 PM   #7
Year: 89
Coachwork: thomas
Engine: 7.3 diesel
using grade 8 bolts and nuts with washers and lock washers, that should do the trick.....
Please advise ASAP NEED HELP VuduVudu Skoolie Conversion Projects 10 07-16-2014 01:21 PM
Purchase Advise for 1994 Thomas bus-bro Conversion General Discussions 2 08-21-2010 02:44 PM
need advise to buy a schoolie for a conversion tfdfyrman Conversion General Discussions 18 06-02-2009 09:02 AM
I need power advise. Train-train Conversion General Discussions 7 11-02-2007 09:16 PM
