Old 08-30-2013, 06:01 AM   #1
Bus dad's Avatar
Year: 98
Chassis: TC 2000 RE
Engine: 8.3 cummins mechanical
NEED OPINON ASAP on new bus
We currently have a 36 ft TC 2000 Front engine wiht a 545 and 4.38 rear end. Mileage is 10-13 depending n speed ( rpm) 55- 13 65 -10. We max out at 68-70 ( flat nose wind dependent) We are planning on buying a pusher next week but it is a high ceiling 40ft with a newer 5.9 (not isb) with a 643 and 4.78 rear end.
Can anyone tell what speed/mpg to expect form a 40 foot BB Rear with a 5.9 643 tranny and a 4.78 rear end. We will be driving it back from out west.
I am having concerns since I have read some post where this rear end they had the tach buried to go 62. But I did not know that "posts" tranny.
Will the 643 get better mpg/speed than the 545 even though they are both 1:1 since it is lockup
What kind of mileage with this config @ 55-60????
David
Bus dad of 3 and husband of 1 ( wife that is )
Bus dad is offline   Reply With Quote
Old 08-30-2013, 10:25 AM   #2
opus's Avatar
Chassis: All-American R/E
Re: NEED OPINON ASAP on new bus
Shooting from the hip; I dont think you are going to do as well as the bus you are replacing for mpg or speed. The 643 is however a huge improvement.
You are adding height and length, which is weight and resistance.
Old 08-30-2013, 09:39 PM   #3
Moderator
crazycal's Avatar
Engine: DT408, AT545
Rated Cap: 23 500 gvw
Every bus is different even with the same specs. I doubt the tach would be pegged with a MT643 and a 4.78 rearend @ 62 mph. The 643 is way better than a 545 on the freeway.
I'm hungry!
You Gotta Let Me Fly
Old 08-31-2013, 12:14 AM   #4
Rated Cap: 47
Is the tire size the same?
Motobus is offline   Reply With Quote
Old 08-31-2013, 08:11 AM   #5
Bus dad's Avatar
Year: 98
Chassis: TC 2000 RE
Wow what a last 24 hrs. We looked at 40 in Detroit and realized to long. As a long shot we happen to look at inter w 466e and 5speed md3060. Now get this it was geared to do 65 @ 1650 rpm. It did have some rust. It drove better than bb, turned sharper and quieter. I know most like bb. I was a die hard 5.9 guy but to get a world tran 1650 rpm for 3500 with some rust. Any opinion on 2001 int amtran w 466e
David
Old 08-31-2013, 11:32 AM   #6
opus's Avatar
The DT is a great engine! Economy won't be as good as a Cummins but I wouldn't let that turn you away. Can't comment on the amtran part, those were after my skoolie service days.
That's a nice gearing setup.
Old 08-31-2013, 06:12 PM   #7
Any tranny is better than the slip-o-matic 545....466 is a sleeved engine correct,which means you can do an in frame.....
Mileage I don't think will be different....but! I "think" jakes can be added to the 466...am I right?
Old 09-01-2013, 08:54 AM   #8
turf's Avatar
x2
the one with a retarder would be my pick
Turfmobile Build Thread
Old 09-01-2013, 05:10 PM   #9
x2
Is that the shorter one
Old 09-01-2013, 10:03 PM   #10
opus's Avatar
After using both, I would choose the retarder.
Please advise ASAP NEED HELP VuduVudu Skoolie Conversion Projects 10 07-16-2014 01:21 PM
Mexico experience? HELP! ASAP. fairlydangerous Conversion General Discussions 8 01-08-2014 07:33 PM
Need advice asap. MilesnElijahsmama Conversion General Discussions 20 08-29-2013 01:22 PM
need turbo ASAP the_experience03 Classifieds | Buy, Sell, Swap 0 02-26-2010 06:57 PM
Broke down in Nashville need advice ASAP lapeer20m On the Road | Travel, Trips, Camp Sites, Tailgates 0 06-16-2007 01:03 PM
