Old 06-16-2011, 06:31 PM   #1
somewhereinusa's Avatar
Chassis: AARE
Engine: 3116 Cat 250hp
Re: Need some Multimeter help
Get one of these http://www.amazon.com/P3-Internation...8266826&sr=1-6
It will pretty much tell you all you need to know. I have one and it does a great job, you can also find out how much current each of your appliances use.
BTW--propane engines have carburetors.
Old 06-20-2011, 11:26 PM   #2
sportyrick's Avatar
Chassis: F33695
Engine: 427 chevy
that cheap harbor freight meter wouldn't work, the meter has to specifically say HERTZ, I have a Fluke 78 that is specifically made for automotive work and has hertz and I love it for setting my welder and generator RPM's . Sounds like a governor setting, my Onan "hunts" a little bit when cold, just is a choke adjustment on mine. sportyrick
Old 06-21-2011, 07:34 AM   #3
bapos's Avatar
Chassis: 2001 International RE
I have a gas generator that had a carb problem that did the same thing. I ended up replacing the carb and its all good. I dont want to call your carb an issues but I would say its carb related even if its an adjustment.
