Old 04-29-2009, 08:24 AM   #1
Re: New owner of a 95 International
your local auto glass or window company can advise you about replacement glass, just make sure that it is safety glass with plastic laminated inside or tempered glass that crumbles when it's broken.
look real close at your sahock absorbers and their rubber mounts/bushings, then look at the spring bushings on both ends of the springs. does the rear suspension have "overload" springs? they look like 2 sets of springs, one mounted on top of the other, the bottom set is bushed and fastened to the chassis, the top set contact a set of stops after the first set start to settle down under load, you could be hearing the top springs hit the stops when you hit a bump.
Old 04-30-2009, 07:23 PM   #2
Im guessing you are in Cincinnati? Just look under auto glass in the phone book and you'll find some near you that can help. I've used Brad's Glass out east.
For brake pressure, I know this may be too simple, but did you check brake fluid?
Castro is offline   Reply With Quote
New bus owner - what can you tell me about my bus BelltownBikes Conversion General Discussions 12 03-03-2013 08:49 AM
Proud new owner of a 95 international baadpuppy Skoolie Conversion Projects 3 05-10-2010 10:34 AM
Hello-new short bus owner here sdwarf36 Short-Bus Conversion Projects 11 10-11-2009 08:27 PM
New member - New owner SlowMotion Everything Else | General Skoolie Discussions 4 05-03-2009 09:29 PM
Big Blue has a new owner!!!!!! bdavis441 Skoolie Conversion Projects 35 05-28-2007 11:15 PM
