Old 05-30-2018, 09:22 AM   #1
IanT720's Avatar
Year: 1972
Engine: 366 BBC
Cool New Roof Deck Fastener!
In my hunt to figure out how to secure brackets to my bus to support my roof deck, I found a cool product!! Its called Box Bolt, basically a beefy drywall moly. That installs in a blind hole..
Theoretically, I should be able to install it from the outside, since my interior is finished, and it will secure it just as well as nuts and bolts but with the convenience of screws! Thoughts?
Living the dream in the Swag Pad!
IanT720 is offline   Reply With Quote
Old 05-30-2018, 09:31 AM   #2
somewhereinusa's Avatar
Chassis: AARE
Engine: 3116 Cat 250hp
Looks like it should do nicely. Easier to install than a riv nut. I went to their website and specs look good. Just be sure to install into a rib not just the sheet metal.
Old 05-30-2018, 10:43 AM   #3
Year: 1994
Engine: DT408 6.7L L6
I thought the top of the hat channel pointed inwards. Will there be enough flange material to secure it?
~Alf
My Build Thread!
djdalfaro is offline   Reply With Quote
Old 05-30-2018, 10:51 AM   #4
Chassis: AARE
They do but, the flange, at least on my Bluebird is about !/2 inch wide. The factory installed roof rack is just installed with lag screws into the flanges.
Old 05-30-2018, 12:16 PM   #5
Year: 1994
1/2" seems pretty narrow when I think about how thick the actual bolt would be after taking into account the thickness of the sleeve. Maybe buy one and try it out on a similar sized piece of metal before buying them in bulk. But then again the bolt itself wouldn't see the bulk of the sheer stress.
~Alf
My Build Thread!
Old 05-30-2018, 02:20 PM   #6
If you go into just the sheetmetal it will deform very quickly. probably instantly.
Roll Your Own Build Thread
Old 05-30-2018, 02:41 PM   #7
Engine: CAT 3208
Rated Cap: 84 pass 36200 gvw
Since the smallest they seem to make (5/16") requires a 5/8" hole I don't think these would work very well through a 1/2" flange. I would be more inclined to use a 3/8" self-threading screw through the flange material. It requires a much smaller drill ( than 5/8") and if you did one through each flange of the same rib, it would be as strong. IMHO
Bob
snonut is offline   Reply With Quote
Old 05-30-2018, 02:57 PM   #8
If you can, try closed end blind rivets in stainless.
Old 05-30-2018, 03:25 PM   #9
Coachwork: integral
Rated Cap: 37,400 lbs GVWR
What's their pull-out strength?
For when I secure my overhead kitchen cabinets into the roof ribs, I bought some Bollhof S25PB280 pre-bulbed Plusnuts in 1/4"-20 thread. Imagine a Jack Nut on steroids. Several companies make similar crossnuts, but the Plusnuts seem the strongest and best. Not cheap, but the best usually never is. They will go through the roof ribs from underneath, and I will make the entire cabinets from 6061 and steel angle so they're not going to ever move!
Jack Nuts are pathetic, Rivnuts are OK for light loads as long as their hole is exactly the right size and not even a few thou over, and forget about trying to thread into thin steel for a machine screw, or using self-tapping screws in hard steel.
For my roof's central walkway to which the eight big solar panels are hinged, I bolted up from underneath with stainless socket-head 3/8" bolts through each rib, 36 in total, plus another 36 5/16" bolts for the panels' struts, so I've got 72 stainless bolts for everything up there. It's solid. You could probably lift the whole bus off the ground by its solar panels!
Old 05-30-2018, 04:05 PM   #10
IanT720's Avatar
Year: 1972
Engine: 366 BBC
I've seen people on this site use coarse sheet metal screws before... So I have to imagine these are at least way better than those... The middle of my roof will be taking load too... Has anyone found smaller and cheaper "box Bolts"?
