Old 02-16-2013, 11:54 PM   #81
usmcbay's Avatar
Coachwork: Thomas MVP
Chassis: Saf-T-Liner ER
Re: New Skoolie here... 1995 Thomas 12row rear Engine
Originally Posted by Shawn&Matthew
Hi! My boyfriend and I recently began the process of converting a bus to live in full time in the Appalachian Mountains. I'm lost as to whether I need one of the 4gmp tankless water heaters from Home Depot, or if I can get away with something smaller? Are you still living in your bus full time? If so, how do you like your hot water heater?
Thanks,
Shawn
I like my Water heater however on very cold days I have to choke the flow of water to allow it to heat up... if the outside temp rises then so does the temp of my water accordingly... so I have to loosen the flow regulator a bit. Also I can compensate this adjustment at my shower head. Also I use NO cold water... It's just straight from the HWH... My shower head is a Pex Manifold which does NOT blend the Cold and Hot - its cold on one side and hot on the other... so I just use the Hot side and regulate that. A real shower head may alleviate that problem but I wanted my water to come out at the roof so I opted to make my own shower head.
And yes I am in it full time.The on demand is great!!!!! Only takes a few seconds to go about 15'...
Here's my Bus Conversion...
viewtopic.php?f=11&t=12202
usmcbay is offline   Reply With Quote
Old 04-08-2013, 02:54 PM   #82
usmcbay's Avatar
Got the Fireplace Stoned in with a 46" Samsung up Top... Working on the kitchen now!!!!
Old 04-08-2013, 04:52 PM   #83
Year: 1974
Engine: Detroit Diesel 6-71
Usmcbay,
Do you think now it definitely would be worth pulling the roof down, spraying the foam then putting the metal roof back in, or put maybe wood back up instead? We're definitely going with spray foam inside with elastomeric coating on the roof when we get our bus, . Also, did you lose much interior space with the foam? How are your temps on the floor?
And your fireplace looks great! Nice job!
Proud new owners of a 1974 Crown Supercoach - the big rolling twinkie!
viewtopic.php?f=9&t=466562
inkblots84 is offline   Reply With Quote
Old 04-08-2013, 07:49 PM   #84
roach711's Avatar
Rated Cap: 19
X2 on the fireplace. Great looking stone work.
The Roach Motel
Old 10-21-2013, 11:06 AM   #85
usmcbay's Avatar
Thx... Now I've got my Dash completely tore down... It looks scary but I've got it all documented what goes where!~ (I think!!!)
I've laminated the dash with an African Wood Laminate - it looks amazing so far. I had a lil accident with a Candle : / so now I have to redo a bit of it. but all and all still living 100% in a Bus and LOVING IT. It's been 1.5yrs and I've enjoyed everyday of it...
Old 10-21-2013, 11:14 AM   #86
good to hear, and welcome back
Old 10-21-2013, 11:24 AM   #87
usmcbay's Avatar
Thx... I'm going to have to tackle some pretty tough things coming up... Installing my Generac RV generator I got LAST YEAR!
Make some storage and Propane storage under my floors accessible from the sides (Typical RV / Greyhound access type doors)...
Old 10-21-2013, 12:35 PM   #88
usmcbay's Avatar
Originally Posted by inkblots84
Usmcbay,
I'm sorry I'm just now replying... Here's my only hindsight issue if I would have sprayed the roof... I'm going to put some 12v LED lighting in at strategic points (I currently use magnetic lighting) such as in the Shower, over the Stove, Sink, and Prep area... Over my Folding Dinning table when I get it in, and in the Bedroom and Bathroom and over the Driver seat... so if I would have sprayed the ceiling with foam i wouldnt be able to fish for the existing 12v wiring...
BUT - having said that - I would not disagree if you are willing to do it - it would be time and money wisely invested~!!!!!!!
For the folks with rear engine skoolie's BUSBOZO Conversion General Discussions 10 10-13-2018 06:16 PM
1995 Ford Thomas for Sale Michigan Brian2417 Classifieds | Buy, Sell, Swap 1 12-27-2014 09:57 PM
1995 Ford/Thomas Built Bus - $2995 Jarlaxle Classifieds | Buy, Sell, Swap 3 04-18-2010 08:56 AM
1995 International Thomas Billsman Short-Bus Conversion Projects 5 04-27-2008 09:17 PM
1995 Thomas Ford with Cummins 5.9 Allision MT643 135K asnowsquall Classifieds | Buy, Sell, Swap 11 12-08-2006 11:00 PM
