Old 08-18-2017, 02:25 PM   #41
The reason I'm looking to do it is that I want to relocate the master bed to a loft bed to give me more floorspace. Not looking for a hot tub room etc. 😎 I want the rear to be my main entry. I've actually seen a couple hacked up car hauler buses dirt cheap localy . with all e stress and time done cutting it up already one could just start from scratch and build a cabin to fit. Hoping to find one wit a diesel. So far they are gas and I'm not a fan of those.
mdemar1978 is offline   Reply With Quote
Old 08-18-2017, 02:43 PM   #42
mmoore6856's Avatar
Chassis: chevy
Engine: 3116 catapillar
Ok lets go mad max and put some chain saws on each corner so we cut our way thru
mmoore6856 is offline   Reply With Quote
Old 08-21-2017, 12:21 AM   #43
You guys are all missing the obvious do a popup type setup for the roof raise just make sure you have low height furniture up there leave it down while driving up while parked hell u could even hook it up to a couple of hydraulic cylinder so all u gotta do is flip a switch and its up in seconds
Sent from my SM-G930F using Tapatalk
nh15reisb is offline   Reply With Quote
Old 08-21-2017, 12:42 AM   #44
mmoore6856's Avatar
Chassis: chevy
More loose stuff to rattle and squeak you say?
Old 08-21-2017, 01:03 AM   #45
I would think as long as you secure it properly it shouldnt be too much of an issue when i get around to doing mine ill let u guys know how it works out
Old 08-21-2017, 01:04 AM   #46
mmoore6856's Avatar
Chassis: chevy
And leaking stinking hydraulic oil on the inside ill pass as 12 ft is not a issue. Remember a solid roof contributes to its strength what you suggest would flop around
