Old 09-01-2017, 04:25 AM   #1
Year: 1959
Coachwork: Western Flyer
Engine: International 450 RED
no metal floor...only wood
so i am just about ready to tear my old 3/4 inch plywood out, and here is the thing man - the plywood is the floor, there is no metal under it, just rails every few feet or so and the frame.
now i think i already know what im going to do, but i would like to hear some suggestions!
keep the old floor? replicate new floor with new ply? skin the bottom with sheet metal? steel? aluminum?
flyer is offline   Reply With Quote
Old 09-01-2017, 05:32 AM   #2
TimeTraveler's Avatar
Coachwork: Blue Bird - mini bird
Chassis: chevy P30
Engine: 6.2
Rated Cap: 36!
so what your saying is, after the ply wood is removed you can see straight to the ground?? as in outside? 0.o
"not all who wander are lost"
TimeTraveler is offline   Reply With Quote
Old 09-01-2017, 06:15 AM   #3
joeblack5's Avatar
Year: 98
Dory has coated plywood only. No rot and no corrosion. Seeing the problems of rust and rot and the very limited advantages of steel under wood in a moisture trapping design.
If it is factory and original then I would be very happy with it.
Later j
Old 09-01-2017, 09:47 AM   #4
New2Skool's Avatar
Coachwork: Carpenter Body
Rated Cap: 65 to Zero. Folding Chair
Interesting!
I like it and it must have been the standard in the 1950's.
Personally, I would replace it either way.
Go with a green treated lumber or something a little heavier.
One inch board or even thicker plywood but, then I am a big guy.
Give it a nice water proofing sealant and rhino liner or something.
What a lot of options and how exciting.
I would have loved to have had the ability to remove the entire floor and start from scratch.
D.L. Jones III
"The Independence"
98 International
New2Skool is offline   Reply With Quote
Old 09-01-2017, 09:56 AM   #5
Coachwork: integral
Rated Cap: 37,400 lbs GVWR
If the plywood floor is still OK, leave it. Not having steel underneath, unlike most typical school buses, is beneficial - water cannot be trapped there and rot the wood and rust the steel. My bus, like all Crowns, also has no metal sub-floor: it has 1.5" of very dense marine ply laid straight on top of the frame rails and substructure.
Is yours a front-engine bus?
Old 09-01-2017, 09:56 AM   #6
Clayton's Avatar
Coachwork: Thomas 72 passenger
Engine: 230HP DT466 engine MD3060 transmission
I would replace the wood exactly as it was. DO NOT use green pressure treated wood. That stuff reacts with metals and causes corrosion, especially aluminum. Its is slightly toxic. And it is not properly dried like regular wood is.
Clayton is offline   Reply With Quote
Old 09-01-2017, 01:44 PM   #7
Year: 1966
Coachwork: Ward-AmTran
Chassis: international S-Chassis #1653
Engine: Int. 9.0L 165bhp / AT545
Pics! Or it didn't happen' ;)
Walter is offline   Reply With Quote
Old 09-01-2017, 02:28 PM   #8
Year: 1959
this is a front engine bus! ill get some pics once i figure out what the best way to show this. i havent torn the floor out yet.
cheers.
Old 09-01-2017, 10:12 PM   #9
Year: 1994
Coachwork: Bluebird TC2000
Chassis: TC2000 City transit
My 1999 Gillig Phantom only had a wood floor. (maybe it is a California thing?) It survived living in Ohio and Michigan all this time. I just scrapped it due to many other issues!
ABdriver is offline   Reply With Quote
Old 09-01-2017, 10:36 PM   #10
Coachwork: integral
Just out of curiosity, what were those other issues? Did it have frame and body cracking?
