Old 03-16-2004, 07:17 AM   #1
Vern1's Avatar
Engine: 345 IH gas
Rated Cap: 66 passenger
Nuts, bolts and busted knuckles
Greetings,
I was removing the driver seat and seat belt to start installation of the new carpet, seat belts and seats yesterday.
I had my son on top with a 1/2" breaker bar about 18" long and I was underneth with a 1/2" ratchet of about the same length.
Needless to say, this was a struggle and even with the proper fitting big tools and lots of leverage, my son and I still have a couple of busted knuckles each!
So, the question is:
What's your busted knuckle count???
I would give mine, but I ran out of fingers and toes to count 'em on - LOL!!
Cheers,
Vern1
1976 International Wayne - ON THE ROAD!!
https://www.pettypb.com/bus
Vern1 is offline   Reply With Quote
Old 03-16-2004, 07:48 AM   #2
Les Lampman's Avatar
Ouch!
Les Lampman
1982 Thomas Saf-T-Liner Pusher "Illusion"
Skoolie.net Gallery
Illusion's SmugMug site
Les Lampman is offline   Reply With Quote
Old 03-18-2004, 02:29 PM   #3
lapeer20m's Avatar
I had my g/f at the time hold the wrench inside the bus while i crawled underneath with the rattlegun (impact wrench) The wrench on top just needed to be held at the proper angle, then it would spin, hit the seat post and not require any muscle to keep it in place. I was able to break one or two bolts starting off, but i also stripped a couple of the bolts. The angle the wrench on top was held wasn't ideal, and allowed the head of the bolt to get stripped.
After 2 or 3 seats, i gave up on this idea and fired up the angle grinder. I ground the heads off of the remainder of the bolts. It was late december in michigan, and crawling under the bus with my carhats on just wasn't much fun.
« fans | Bookmobiles »
RIVET vs SPOT/PLUG WELD vs "BOLTS" vs GLUE etc. ol trunt Everything Else | General Skoolie Discussions 2 03-04-2014 11:42 AM
Check your U-bolts!!!!! M1031 Mechanical and Drivetrains 15 10-05-2012 01:59 PM
Ford 7.3l turbo bolts back out. roach711 Ford Drivetrain 1 03-29-2012 05:39 PM
Seat Bolts Rusted Through Skoolie BOBB Conversion General Discussions 1 07-07-2005 11:59 AM
