Old 12-12-2010, 10:17 AM   #1
Diesel Dan's Avatar
Engine: DT466/AT545
Re: Obvious question, obvious answer
In my Thomas bus, that handle is a release for the doors. It is attached to a cable that is attached to a locking plate inside the bus. If I don't throw that lever, I cannot open the doors. My guess is that someone disconnected your lever and the locking device inside the bus so the doors can be pulled open directly. My lever has a small cabinet lock in it which will prevent the lever from moving, and I had a key made, but the key does not operate smoothly at all, so I will need to come up with a different locking mechanism, or I suppose I could try to fix the lever/lock.
Gallery:
Conversion Thread:
viewtopic.php?t=4959
"Thank you, Captain Obvious" Scooternj Skoolie Conversion Projects 87 01-31-2016 12:30 PM
Who wants to answer a butt-load of questions??? SeanF Conversion General Discussions 11 11-22-2009 10:24 PM
I may have found the answer! Ob1 Conversion General Discussions 7 10-02-2009 07:29 AM
hopefully someone out there has an answer for me !!!!!! abdabbs Skoolie Conversion Projects 15 03-31-2009 12:50 PM
