Old 08-14-2008, 01:08 AM   #11
crazycal's Avatar
Re: Ok, here's an idea for the floorplan/layout I'm thinking of
He's our fearless leader. Shame on you. Unless you were kidding, then shame on me.
http://www.skoolie.net/forum/memberl...iewprofile&u=2
I'm hungry!
You Gotta Let Me Fly
Old 08-14-2008, 08:06 AM   #12
My black/grey tank is located center of my bus between the frame rails, behind the rear axle. The toilet is next to the passenger side wall behind the wheel well. This setup will use a bit more water with every flush but hanging my 55-gallon black/grey tank from the frame rails was just to easy to pass up. We will be carrying 50-55 gallons of fresh so I am not concerned. A 42-gallon fresh water tank, when it runs dry I plan to add 10 more gallons from two plastic 5-gallon jugs (we always carry 3 fivers now) the third 5-gallon jug always sits outside on a table so it will never enter the bus's water/holding supply.
Abbott is offline   Reply With Quote
Old 08-20-2008, 11:49 PM   #13
nchittendon's Avatar
Send a message via Yahoo to nchittendon
I mean, who is going to buy a 20-year-old 35-foot bus with no seats that gets 6 mpg for fun?
YO! Over here, in the back! **shouts loudly with arm raised in the air hopping like I have to pee**
lol
nchittendon is offline   Reply With Quote
Old 06-17-2009, 08:22 PM   #14
Can you put of some Posts with signs that state all violators will be shot if found on the property? Doesnt mean that a gun has to be involved, but it should make people think before they step onto the property.
Old 06-18-2009, 08:08 AM   #15
Known Problems:
Turn signal bleed to reverse lights (Don't even want to guess)
Roof and windshield leaks, with minor interior/roof damage (floor warpage and a rotted trim panel)
Side Door lock not working properly (Looks like a standard door lock, but I'm sure it isn't)
Glow plugs not functioning (may be disconnected)
Water in fuel (discovered after driving, sounds like a popcorn machine below 1800 rpm)
Driver's windshield needs replacing (gasket alone is $400)
The first problem sounds like a bad ground. RVs often don't have any real metal where the lights are mounted, so the ground has to be wired over from a chassis point. That should be an easy fix if you are at all comfortable with chasing down wires.
Roof leak can be patched with Eternabond putty tape. I got mine at bestmaterials.com for a decent price. It is a strong putty tape that is almost impossible to peel back off and seals really well.
What are the dimensions of the windshield? I have an old RV with 2 large pieces of undamaged glass that will be coming out soon. If the dimensions match, we might be able to work something out.
The side door on my rv has a functional lock, and will also be coming available shortly.
Can't help with the glow plugs. sorry. Or the water in the fuel.
I *think* the gaskets on my windshields are still in good enough shape. However, I'm positive you can find a better price than $400 each. And like I said, the glass is in good shape and who knows, they might just fit.
It'll be easier to sell with as many of those things fixed as possible should you choose to sell it.
Oh, and rebuilding the interior of an RV is more work than starting from scratch with a skoolie. Also, when you get done, you still have a stick-and-staple RV that won't survive a rollover.
hope this helps,
jim
baadpuppy is offline   Reply With Quote
Old 07-09-2009, 12:07 PM   #16
Griff's Avatar
Year: 1982
Chassis: IH S1723
Engine: IH V345 Gas V8
...In reference to another thread, does anyone know where I can get enough tinfoil to line the roof of my bus?
Here's where I got mine: http://www.restockit.com/Heavy-Foil-Rol ... --(627REYN)---ON-SALE-TODAY!.html
I'm also experimenting with stealth paints and non-standard surfaces like the military uses on the newer aircraft. Hopefully when I'm done, my bus will just look like a highway mirage heat ripple coming down the road, WATCH OUT!
Griff is offline   Reply With Quote
Old 07-09-2009, 06:27 PM   #17
Smitty, He IS thinking green...well, white probably. If he can reflect enough of the suns rays out into space, he could cause it to snow around his place... One problem though, too much reflection and he could cause another ice age... But, on the upside, it would cool the entire planet.
Old 07-11-2009, 04:46 PM   #18
I dont think we are on the verge of one, Just been watching too much of the science channel again... Reflecting heat isnt going to cause any real warming. I mean, the reflector will get a little warm, but other than that, nothing.
And anyways, someone had to counter Smitty.
Old 01-29-2010, 08:42 PM   #19
Cheese, excited to hear about the studio idea. I'd like to do something similar, only a little more low tech as it will be more a practice space, doubling as the bedroom. all I want to do is soundproof the back area of the bus so no sound gets out. I just decided this in favor of my other idea which was to build a towable room on a flatbed - more expensive than I can afford and probably make drive more difficult. there's just so many options for products and methods, and I don't know how any of it will stand up to being on the road. what are your thoughts on this so far? I'm hoping to accomlpishing something for far less than $2000 if possible!
jndonnelly is offline   Reply With Quote
Old 01-29-2010, 09:46 PM   #20
Yes, possible theft was a concern too, although just for kicks I pondered making it look like an outhouse and storing all equipment in bus when not in use!!!
My needs are much simpler, I'm satisfied with my M-box and a laptop that can run Protools (full version). storage I think will be less an issue since, as this space is doubling as the bedroom, the bed will have full storage underneath, accissible by way of a hinged lid that can be propped up with the mattress still ontop. should be just big enough for a Yamaha electric piano and a couple stringed instruments. I'm less interested in recording quality and more so in privacy, both from the outside, and from the rest of the bus.
Right now I'm looking into building techniques, like a room-within-a-room, or resilient channel and related spinnoff methods, and this is the part I'm most concerned with standing up to bouncing around on the road. not to mention this all takes up precious space. I've been looking into whether sound dampening materials like Rattle Trap or Dynamat would work to isolate the space, since these are used with vehicles and reducing home theater noise, but it might not accomplish the level of privacy I want.
also considering lamenated windows to replace the glass in this area. I don't want to work or sleep in a sealed off box, so as tricky/pricey as it sounds, I'd love to make that work.
Thinking about maybe picking this up good or bad idea? bapos Conversion General Discussions 2 01-20-2014 07:49 PM
Refined layout idea thesaltydog24 Conversion General Discussions 5 11-01-2009 09:05 AM
Floorplan brainstorming TygerCub Conversion General Discussions 1 10-26-2009 04:39 PM
Floorplan questions jksmileyface Conversion General Discussions 5 04-06-2009 01:08 AM
Revised Floorplan SeanF Conversion General Discussions 0 10-31-2008 07:14 PM
