Old 06-22-2011, 06:57 PM   #1
lornaschinske's Avatar
Rated Cap: 89
Re: Ok, I have a really "weird" question.
I don't think you want to do that. Not much sticks to my elastometric coating. If you use a foam roller and apply in several thin coats (don't load the roller up heavily and allow dry time between) it will make a lightly textured surface. Should look okay on the roof.
Fulltime since 2006
Old 06-23-2011, 04:39 PM   #2
Ob1
Year: 1963
Coachwork: Grumman
Chassis: Chevrolet
Engine: Chevy 292 I-6
Dont try and topcoat the rubber paint! You will have a mess that makes correcting your "so-so body work" look like child's play.
Which it is, but then again, I have a P+B shop.
My suggestion: put some more labor into your body work, etch primer, wet sand with 400 grit, prime with 2K primer, wet sand with 600 grit, top coat with an industrial acrylic enamel. Get suggestions from the paint store about the proper reducer, let them know how you intend to apply it.
Ob1 is offline   Reply With Quote
Holding tanks in heated "basement" question... Locutus Plumbing, Water and Waste 12 01-06-2014 04:30 PM
1986 Intl/Thomas Conventional, DT466 5speed, "Big Blue Bus" thrash Skoolie Conversion Projects 8 08-25-2013 11:57 AM
"Short" bus or "Regular" bus? TygerCub Conversion General Discussions 11 03-03-2012 12:37 PM
"Tutorial" and "How To" internal error dunnwright Conversion General Discussions 6 11-16-2010 07:02 AM
