Old 07-20-2009, 11:30 PM   #1
the_experience03's Avatar
Re: Okay, here's another weird thought.......
It would eliminate some changes in form of energy which certainly should help. The biggest issue is with sizing things correctly. You'd need a compressor off something large (like say a van or large SUV with rear air) if you ever wanted to be able to get the compressor to cycle off. I'm not sure how you would do the lines. I suppose you could try silver soldering them. Flared ends just don't work with R134a like they did with R12. Some experimentation with the evaporator size and orifice tube though and I think it could work reliably. AC compressors do require a staggering amount of power though. Drive a Ford Focus/Escort/Contour. You can actually feel the engine lug and speed decrease slightly when the compressor engages at highway cruise with the torque converter in full lock up. There is a reason why there are WOT cut outs and overrunning clutches used on those compressors on some cars!
Old 07-21-2009, 12:58 AM   #2
So you're talking about using propane as the fuel or the refrigerant? Propane (R290 I believe) makes an excellent refrigerant, but is pretty much limited to stationary units. Pumping pressurized, heated propane around in something that has the potential to sustain substantial damage (i.e. a vehicle) is not considered to be a terribly safe idea, notably because evaporator leaks would result in propane in the occupant cabin.
Propane fridges simply use the propane to heat an ammonia mixture that acts as the refrigerant. There is no compressor.
Old 07-21-2009, 12:17 PM   #3
has anyone looked at semitrailer referigeration units, they are self contained, other than that i,m uninformed.
Old 07-21-2009, 12:49 PM   #4
I found some information online about absorption air conditioners, and in the examples given, often solar thermal was the heat source for the absorption process.
http://www.solarpanelsplus.com/solar-air-conditioning/
http://www.treehugger.com/files/2006..._powered_a.php
http://en.wikipedia.org/wiki/Solar_air_conditioning
The downside is that it appears companies are targeting large commercial applications rather than small home or mobile applications. There may be a point where making it smaller makes it stop working, or it may be that this is still in its infancy.
I think refrigeration of all types is going to require a lot of energy, whether it be thermal, mechanical, or electrical.
The most common example of absorption refrigeration seen today is the RV refrigerator. The same principle should work for refrigeration, freezing, and air conditioning. In an RV fridge, they use 12vdc, 120vac, and propane to input the heat. I don't know what temperatures they need. I read somewhere that they get less efficient when it is hotter outside.
Evacuated solar tubes are relatively inexpensive (see http://www.beyondoilsolar.com/solar_water.htm), and ought to be able to be mounted on the roof of a bus. There are also propane and diesel and kerosene fired small boilers out there that can also be used to heat water. Hot water ought to be able to be used to heat the hot side of an absorption process. As a side effect, you would also get winter time heat, and hot water out of the process.
I'm continually looking for lower energy alternatives to air conditioning (and other forms of refrigeration). So far I haven't found much useful though.
I'm planning to make hot water an important part of my energy plan in my bus. I plan to use radiant heat, and supplement that with heater cores with fans. I'm planning to have multiple sources of heat to input to the system, including the engine, solar, a diesel boiler, and a propane boiler. I plan to have multiple zones of output. If I can figure out a way to integrate that hot water system with an absorption refrigeration system, I will do so. My boilers will be located outside of the living space, preferably all together and in a nice fire-safe space. Actually, the core of the system will be a closed loop glycol mixture system. I'll use a liquid to liquid heat exchanger to connect that to the engine and also to provide hot potable water. I know I'll also need an expansion tank.
I suspect that in the short term, I'll have to stick with a conventional compressor based refrigeration setup. Long term though, the absorption stuff looks quite promising, especially when you remove the need to provide the flame directly to the refrigeration system (by transferring it via the hot water/glycol plumbing).
I'm still learning about this stuff as I go along, so take that into consideration when reading this. I don't know if my ideas will work out in reality, but I sure plan to give it a shot.
jim
baadpuppy is offline   Reply With Quote
Old 07-21-2009, 06:44 PM   #5
So Cheese...why do you want to use propane as your refrigerant, anyway? I understand that yes, it is a pretty decent replacement for R22 which many AC units use, but I still don't see the appeal of it unless you are converting something like a window shaker to a split unit which may or may not be the best route to take. Just what kind of compressor are you looking at using? Traditional R22 is readily available, as are 410A, 407C, 134A, etc.
Old 07-21-2009, 09:24 PM   #6
I have a buddy that works for a commercial refrigeration company so I will explore the intricacies with him.
our weird little prison windows pictureLOVE Conversion General Discussions 15 09-19-2014 02:44 PM
Forum is looking weird Skunky Bus Forum Admin | Account Help | Suggestion Box 6 02-19-2012 10:28 AM
What it this button for? (and some weird noises) gbstewart Conversion General Discussions 8 03-17-2011 12:59 PM
Weird Question...indulge me retrogeek42 Conversion General Discussions 1 09-27-2008 08:14 AM
Weird Conversions GoneCamping Conversion General Discussions 11 11-29-2007 07:40 PM
