Old 06-08-2011, 10:32 AM   #1
Hex
Hex's Avatar
Coachwork: Bluebird, Model 3800
Rated Cap: 42
One Tank or Two? (Grey/Black)
Okay, I have to admit that I got into the skoolie conversion via Jake Von Slatt, and in revisiting it, I noted that he only used one tank for black and grey water.
Now, I understand that for long-term use, having a thriving bacterial culture in your black tank keeps smells down, and that lots cleansers in the grey water would kill the cultures, but what would the benefits/drawbacks be to going that route for sporadic short-term (say a week or less) use?
Hex is offline   Reply With Quote
Old 06-08-2011, 05:08 PM   #2
lornaschinske's Avatar
Rated Cap: 89
Re: One Tank or Two? (Grey/Black)
Short term use... so you will never long term?
Up side to dedicated grey/back tanks... if boondocking in an area where you can dump grey water on the ground (out west mostly... don't attempt int he South east), having separate tanks will allow you to drain your grey water out and lengthen your stay. In a weeks time, two people would most likely go thru 25 or 30 gallons black and at least double that for grey. Many folks use the grey tank to "rinse out" their sewer hoses (dump black first, then grey). Fulltimers will keep the black tank closed until needing to dump and leave the grey open to drain in the sewer drain hose (this is what we do). Black tank is nothing more than a holding tank. Forget all the hoopla about bacteria, etc. Just don't use formaldehyde based tank treatments. Most fulltimers/long timers will not use any tank treatment (we don't) and have no problems with smell. Just use plenty of water when flushing.
You do realize that if the tank fills up and "backs up" into the usual place... the shower, you will have poo (and chemicals if you use a tank treatment) in the shower. I've had the grey tank fill up into the shower when we first got the Class C. That was bad enough. With separate tanks, the toilet will just "burp" at you when it fills up to the bottom of the toilet drop pipe.
I know you think you will save a few bucks and perhaps gain some storage space and/or there's no real "need" to have separate tanks but go with separate tanks. At some point it will fill up and back up into the shower. And someone will most likely be taking a shower when it happens.
Fulltime since 2006
Old 06-09-2011, 09:09 AM   #3
Hex
Hex's Avatar
Rated Cap: 42
Hmmm ...
Well, I would guess grey water coming back into the shower, while nasty, would be a whole lot nicer than grey -and- black water coming up.
Thanks!
Old 06-09-2011, 07:48 PM   #4
I agree, I think haveing 2 tanks is the way to, you really dont need black water backing up on you, being able to bleed off grey water is also a benifit.
I have 2 tanks faceing each other , I have the vents tied to gether in a tee its 1 1\2 clean out, i have 1\2 pex line going up into the floor then out the side of the of the bus close to the roof, it works great, both tanks drain fast and no smell. if i need more vent size to drain the tank I just have to open the clean out valve, but I wont have to. and best of all no holes in the roof. as soon as I can, Ill post pics. I just refuse to cut holes in roofs.
Old 06-13-2011, 11:54 AM   #5
Hex
Hex's Avatar
Rated Cap: 42
Thanks! It sounds like your set-up is basically what I was thinking of (100 gal freshwater and more than that for grey/black).
Do you get any problems with stuff 'sloshing' around and making a mess, or issues with being parked where things aren't level (burping or backups as Lorna mentioned?).
Old 06-13-2011, 12:24 PM   #6
Year: 94
Coachwork: b/b
Chassis: tc2000
Engine: 5.9
i use one tank,,most of the time iam in a camp....but when iam not,, i use bleach in the tank and the rv stuff....works ok
keith is offline   Reply With Quote
Old 06-14-2011, 09:10 AM   #7
Hex
Hex's Avatar
Rated Cap: 42
Cool. Thanks for the info!
I definitely want to find some HepVo traps now ...
Old 06-22-2011, 11:06 AM   #8
Stuff's Avatar
being a full timer, of course my TT was made with both tanks. I have had the grey back up into the shower when in it (just rinse my feet off after lol) and then go dump it after. now if it was black and grey in one tank that would been nasty(er) stuff come up for sure! And yes, use LOTS of water in the black tank. nothing worse then the "Mat of doom" building up just under the toilet.
I had a small one last winter build up. I now use "RV Digest IT" and it works great! pretty much once you get a good culture going you dont need to add more unless you rinse out the tank. now adding water when dumping to get more solids out is okay but like filling and dumping, filling and dumping over and over to wash out the tank will take the bacteria with it.
Old 06-22-2011, 06:40 PM   #9
Rated Cap: 89
Originally Posted by richlindquist
Originally Posted by lornaschinske
In a weeks time, two people would most likely go thru 25 or 30 gallons black and at least double that for grey. .
People may fill up a tank that much if they act like they are still in a house ...
Don't forget, trees and bushes need watering now and then too.
Rich
We live fulltime in the RV so it IS our "house". In the Southeast, if you dump waste water (either grey or black) in a public campground/forest unless you are specifically told to do so by a park ranger, then they will boot your fanny out, fine you for dumping "hazardous waste" and (in Georgia) put your name on a list and you aren't allowed to rent a site from them anymore. Campgrounds in the Southeast enjoy a long, heavy use, camping season. We also are always on full hookups unless we are traveling. We do not use tank chems, only H2O and plenty of it.
Fulltime since 2006
Old 06-23-2011, 08:26 AM   #10
TheRainbowBoxer's Avatar
Engine: 5.9 Cummins 12v
Rated Cap: 78 Passenger
I think he may have been referring to directly "watering" the trees and bushes, rather than dumping.
-Dan
"What's the matter Col Sanders? Chicken?" -Dark Helmet
lu·di·crous [loo-di-kruhs]
adjective
causing laughter because of absurdity; provoking or deserving derision; ridiculous; laughable
viewtopic.php?f=9&t=11840
TheRainbowBoxer is offline   Reply With Quote
Old 06-23-2011, 10:36 PM   #11
Rated Cap: 89
... Your RV is your "home" but most people's houses have foundations and sidewalks and magic pipes that take their flushings away.
We fulltimed for 18 months and only had hook-ups four times. Conservation can save water and $$$.
Rich
In our case it would end up COSTING us plenty of $$ in fines from the health Dept. We operate a food cart and are required to have "approved potable water" and an "approved waste system". So we do have the magic pipes that take away our flushings. And in Corpus Christi we also had the sidewalks! I've never had a sidewalk with any house we've owned.
Fulltime since 2006
Old 06-26-2011, 02:27 PM   #12
browncrown's Avatar
Rated Cap: 79 at Birth
For what its worth, I just have one tank in the Crown because of space limitations. The bus has a mid-ship engine and with all the rest of the mechanical workings underneath, it was all I could put in. I don't do much boondocking so it works ok for me and I don't have a big family either to fill it up quickly.
BC
My Conversion Thread: https://www.skoolie.net/forum/viewtopic.php?f=9&t=3065
Old 06-26-2011, 03:40 PM   #13
browncrown's Avatar
The trunk would be an ideal space, but my fuel tank runs wall to wall just in front of the trunk area. In order to get around that, I would need a pump to get the waste water into the tank because they would be uphill if I sat them in there.
BC
Old 06-29-2011, 06:30 PM   #14
browncrown's Avatar
Feel free to look at my conversion here on the pages...I'm always ready to show mine
BC
Let's talk dirty - as in Black and Grey water tanks.... enthe0gen Plumbing, Water and Waste 8 11-25-2013 11:26 AM
RV Toilets, black and grey wars swhite832 Plumbing, Water and Waste 18 10-20-2009 07:17 PM
Fresh, grey, and black water tank size. what do you have? Jerry Campbell Plumbing, Water and Waste 3 10-31-2008 09:56 AM
benefit of having a separate black and grey water tanks? Roasting8 Conversion General Discussions 0 10-28-2008 03:53 AM
black/grey tank size/dimensions instal? beekay Plumbing, Water and Waste 0 10-13-2006 08:57 PM
