Originally Posted by alpine44
Since I made the comment quoted above, I did some thinking considering all comments made in this thread and currently I am leaning towards draining the bathroom/kitchen sinks via HepVo valves into the black water tank under the toilet. The dilution will make the black water easier to empty at the RV dump station.
I may drain the shower water into a separate grey water tank so I can dump that anywhere if waste water capacity is limiting my stays off the beaten path. It is easy to add additional fresh water capacity with jugs at which point the waste water capacity will become the time-limiting factor.
I really don't want to get into this in this thread, but...
Some people consider kitchen and toilet to be "black" and bathroom sink and shower to be "gray". But a strainer in the galley sink accomplishes a lot.
If you use organic, biodegradable soaps and toothpaste and whatever else, you should be able to do what you are saying. Again, if you do this in the galley and use a strainer for food waste, that should work there as well.
As you are saying, another source of water into the black tank is preferable to break up the solid matter. I get where you're coming from in wanting to be able to dump the harmless, or even beneficial water wherever you are boondocking. If it's that big of a deal to you, you might consider the cat box route with filters on the water (and organic/biodegradable products). I did the same mental gymnastics myself and have landed on a single combo tank with no cat box.
However, even while full-timing for a couple of years, I've always been able to find a dump site. Remember, a dump station is nothing more than access to a sewer or septic tank. In the USA, every building needs to have a clean out access point.
You might have to break out a tool. Don't trespass and get beaten up. Restaurants and gas stations are usually the best locations. If the gas station has no dump station in front, look for an access point in back. Be courteous, courageous, and quick! Act like you're doing what you're supposed to be doing.
Clean-out Access Covers come in different types.
TOOLS
For the square female (flush) caps (be very careful with PVC or plastic caps)
Pipe Wrench - Again, be careful with PVC or plastic caps
Channel Locks
Expensive specialty tool ($50+)
And if money is no object:
There are some styles and tools that I've missed. You get the idea. This is better on the conscience than doing something nasty and illegal.
