Originally Posted by Missmichelleb
So, being someone not super familiar with mechanics, is there any benefit to SFA vs SBA? How important is that to consider when looking for a bus for conversion?
This is more common in the world of big trucks, where there is concern for steering geometry (and the ability to make sharp turns), weight distribution, and ride quality. A longer wheelbase (common with the Set Forward Axle) has a wider turn radius (assuming the same steering angles otherwise), but will experience less "bobbing" and "Nosedive" when braking.
Even with a full length bus, I doubt you'll be visiting many narrow residential streets so the turning radius won't be much of an issue while on the road. Your storage arrangement is another matter. I know mine was, which was why I needed a shorter bus. The SFA will give you a little more distance between the axles, which is good for all the "basement" stuff you may wish to add.
For our purposes, I don't think there is much practical difference between the SFA and SBA - maybe a foot or 2 of wheelbase length for an otherwise identical length bus. The SBA would be somewhat easier to navigate through congested city streets and tight turns with its shorter wheelbase.
