Old 10-27-2017, 10:38 AM   #41
Traveling
Engine: 5.9L Cummins
Rated Cap: '00
Originally Posted by Missmichelleb View Post
I’m worried about having enough room for everything with a FE
Thoughts?
Less. is. more.
Old 10-27-2017, 10:53 AM   #42
Originally Posted by Rusty View Post
Lol! Trust me this is a process of getting rid of a lot of “Stuff” I’m more worries about the important stuff when it comes to under the bus, I could live with out storage boxes, but water tanks and batteries seems like really important stuff.
Though I’m sure there are plenty of people who convert FE Type D buses, so it’s gotta be possible.
There’s 5 hours left on these bus auctions I’m looking at.
Still going back and forth on if I should get in there an bid
Missmichelleb is offline   Reply With Quote
Old 10-27-2017, 10:56 AM   #43
I love the idea of having a back door!
I wonder how challenging it is to fit everything needed under a FE Bus, I’m going to be Off Grid living, so I’m worried about having enough room for everything with a FE
Thoughts?
People fit stuff under CE buses, IDK why an FE would be any different. I could fit a generator, all the tanks, and still have storage under my 92 FE.
Old 10-27-2017, 10:59 AM   #44
That’s Great to hear!
Old 10-27-2017, 12:01 PM   #45
CCurran88's Avatar
Chassis: 2003 International CE; 2 A/C Units; PS; Air Brakes
Engine: T444E 7.3L Diesel Engine
Rated Cap: 72 Passengers
This is the bus I have. So far, I've removed all seats, side panels, ceiling panels (all of which were screwed in, NOT riveted, thanks very much), and insulation. I had to grind scale rust from one end of the bus to the other on the floor due to the fact that the school district kept their buses so clean using power washers. No rust anywhere else on the body, just the icky floor. But that floor is now patched and ready to be painted.
We drove her home in April, 4 hours both highway and back roads. She never got above 58 miles per hour, which was fine with me, but my husband wants to eventually replace her transmission with one that will let us get up to 65. No hurry on that either.
I love my Buttercup and wouldn't want any other bus, so I vote yes on this one. Personal bias.
Redheadraptor
CCurran88 is offline   Reply With Quote
Old 10-27-2017, 02:44 PM   #46
Looks like I will be getting out bid on this bus.
I’ll keep looking
Old 10-27-2017, 03:01 PM   #47
The big difference between an FE and a RE regarding storage is the fact that the RE can use the underbelly all the way across...no driveline to work around.
Old 10-27-2017, 03:13 PM   #48
Chassis: Saf-T-Liner MVP ER
It is possible that your bus is speed limited in the engine software. If that's the case, any dealership can change it.
If that's not the case, it is likely that changing the crown and pinion in the rear diff., or changing the differential would be the solution. Either way it's unlikely that a transmission change is necessary, and that's a good thing. They are expensive.
Steve Bracken
Build Thread
Old 10-27-2017, 03:51 PM   #49
CCurran88's Avatar
It is entirely possible this is the case, and we'll check it out. He wants to at least clean up the engine, which has a leaky something or other that is spraying oil, although oil pressure is fine. It just has icky stuff (my technical terms here) inside the engine hood from something. He's the mechanic, I'm just the go-fer at his beck and call. He's rebuilding a transmission on a 98 Dodge Ram 4x4 at the moment, so hasn't really looked at my bus much other than to tell me what a great job I'm doing sanding, grinding, and swabbing.
Redheadraptor
Old 10-27-2017, 04:22 PM   #50
Traveling
Rated Cap: '00
Want to know what I started to do? Take pictures of all the important stuff. Good pictures. They store real easy, copies even.
You will find very creative people on these boards for creating space. Watch some of the youtube videos. One guy raised his roof, then raised the entire floor inside using 2x10 floor joists. He hinged the panels and has tons of underfloor storage and it insulates his floor a bit. Bonus: Pirate vibe.
Your first step is make sure it is THE bus, in good rust free condition.
Go get' em at your auctions, stay disciplined. If it's just you and another guy (watch the bid history) for a few blows, bail.
Old 10-27-2017, 06:09 PM   #51
Good Advise! I’m really stubborn so I need to remember that
Old 10-27-2017, 06:13 PM   #52
Traveling
Rated Cap: '00
re: bid war
You'll need that money in for your build.
Old 10-27-2017, 06:17 PM   #53
re: bid war
So what’s the most you would spend on a bus??
Old 10-27-2017, 07:24 PM   #54
2-5 grand is what I'd pay.
Old 10-27-2017, 08:23 PM   #55
Traveling
Rated Cap: '00
It depends of course. What State are you in ? It will determine "how far" a rust-free bus is- If Alaska, well different story than Kansas. Cost of fuel to get home, potential for breakdown on longer journey, food, hotel, grief, etc.
There should be a rule-of thumb- Don't spend more than 1/3 of your total budget? People will chime in and adjust my ratios.
1/3 Cost of Bus: Tax, license. Ins
1/3 Repairs of Bus: Battery, tires
1/3 Customization
some thoughts.
Old 10-27-2017, 08:33 PM   #56
1/3 Customization
some thoughts.
Fitting out a bus to RV spec can be very expensive. It all depends on what you want in it.
If you go for big solar, high quality new everything, you could spend tens of thousands ... or not. It's your conversion and you can take years over it doing a bit here and there and using it as a mobile tent in the meantime.
My plan will be to strip and refit the interior shell, then add items from the overall plan as and when we can.
Steve Bracken
Build Thread
Old 10-27-2017, 10:43 PM   #57
Originally Posted by Brad_SwiftFur View Post
I *THINK* "SFA" means Set-back Front Axle.
Someone correct me if I'm wrong.
SFA means "Solid Front Axle" as opposed to IFS which means "Independent Front Suspension".
Steve Bracken
Build Thread
Old 10-28-2017, 10:05 AM   #58
Awesome! I was still curious that meant
Old 10-28-2017, 11:53 AM   #59
Chassis: IH
I don't think so, as I have never seen an IH school bus (or any full size school bus, medium or heavy truck for that matter) with independent front suspension. Virtually all of them have solid front axles.
Yes, I am fully aware military and off-road trucks have independent front suspensions, and smaller cutaway-style buses often do too.
Old 10-28-2017, 12:31 PM   #60
Google is your friend. I can't find any reference to "SFA" except "Solid Front Axle". which is everywhere.
Steve Bracken
Build Thread
