Old 03-11-2010, 07:34 PM   #1
Josef's Avatar
Options / Ideas for removing rear heater.
Hi everyone, looking for some advice please …
I hope my reference sketch makes sense.
My 97 Thomas has rear heat which I am removing and no longer want. Question is. I would like to plug the T valves like in option B. That would still complete the circuit/flow, but I wonder if that would force or put to much pressure in the driver heater.
If I looped a patch hose back around in a U shape like in option A, I wonder if that bypass would act as path of least resistance, and less/not-enough fluid would pass through the actual driver radiator. It kind of seems like it would be that way in the original setup anyhow…
So the main question is any reason to NOT just plug ends like in Option B?
Secondly since that’s what I am leaning toward doing ….. Any ideas on how to plug those ends. I don’t want to sweat copper caps on them. The inner diameter of the hose is 1-inch.
There is a rubber cap at http://marineengineparts.com/shopsite_s ... ge372.html I am thinking of using something like this (it’s at the bottom of the page) You think this would be durable enough? Or can you recommend something else?
9$ a pop seems high, called a few parts stores and seems they only have up to 3/4” caps.
Thank you all!
Conversion photos viewable at:
http://picasaweb.google.com/js6011980
Josef is offline   Reply With Quote
Old 02-25-2018, 08:45 AM   #2
I would think you would want to loop it, let the coolant have the path of least resistance if necessary instead of being forced through the heater unit. I am definitely going to loop in my bus.
Alexor is offline   Reply With Quote
Old 02-25-2018, 11:37 AM   #3
Robin97396's Avatar
This has been a topic that we've been through a few times here. It is necessary to make a loop for the coolant to flow as designed. These lines have, been capped off, as you mentioned with bad results. It's possible to create the loop using the rubber hose but it's also pretty easy to design a "U" shaped pipe to loop the coolant back without the possibility of kinking the hose. Don't use a smaller diameter pipe for the "U".
Most of us have removed our rear heaters. Some people relocate the heater to the passenger area for additional heat while driving, but obviously those people live in northern climates.
Robin
Nobody's Business
Old 02-26-2018, 04:24 PM   #4
Coachwork: Girardin
Chassis: Ford E350
Engine: 7.3 Powerstroke
i took my heater out only a couple weeks ago. i had shut offs underneath the floor, so i just cut my lines and shut them off. now the dash heater works fine, but it seems like it has to run longer to get warm, because hot coolant is just sitting down there 10 feet from my motor now. i will shorten my rubber lines up to the metal line at the engine and make a loop. it will be more efficient i think, plus i now can get rid of extra lines underneath.
sugarpinedanny is offline   Reply With Quote
Removing rear heater and 1 inch hosing timbrass Heating, Cooling and Appliances 2 11-24-2014 07:36 AM
Interesting find while removing rear cap of Bluebird SmokinJ Conversion Tutorials and How-to's 5 07-30-2014 10:06 PM
1990 C60 rear end options? reddog GM | Chevrolet Drivetrain 3 01-19-2011 10:25 PM
Removing rear heaters / cap lines? buswizard Conversion General Discussions 4 07-17-2010 08:46 AM
Rear storage / Rear door ideas allanwcoty Conversion General Discussions 0 05-17-2005 12:52 PM
