Old 10-21-2013, 09:25 PM   #11
roach711's Avatar
Rated Cap: 19
Re: Our New Bus
So, is your electrical stuff working now? Inquiring minds want to know!
The warm starter sounds like a problem.
Make sure your connections are clean. The connection in your second pic looks like it could use a good going over. I use emery cloth to sand off any corrosion then coat all surfaces with dielectric grease (available at Home Depot/Lowes in the electrical dept). The grease keeps the connection from corroding again.
The Roach Motel
Old 10-22-2013, 06:05 AM   #12
Year: 1994
Chassis: TC 2000
Engine: 5.9
Re: Our New Bus
Sorry, I should have explained better but when I said the starter was hot I meant it had power to it. Bus is back cranking and running and everything came back on and is working except the light in the stairwell. Haven't had time to check it out, I hope it's just a blown bulb. It was late, so I haven't tried the jacks yet.. kinda gun shy about it. I plan on going out there and giving it a try today. Thanks for all the info, I'm going to get that grease then and fix that up.
huff0026 is offline   Reply With Quote
Old 10-22-2013, 08:22 PM   #13
roach711's Avatar
Rated Cap: 19
Re: Our New Bus
OMG!!!! A light out in the stairwell?????? Sell it NOW!!
Seriously, I'm glad it was a (relatively) easy fix.
It might be a good idea to put a fuse in the jack circuit before trying it to avoid burning wires again. You're reminding me that I need to add a fuse or two to my battery banks.
The Roach Motel
