02-18-2016, 11:53 AM
Overhang
I'm considering a shorty bus as a tow vehicle for my club ford racecar and closed trailer with tools (trailer weight of car+tools+trailer = ~3500lbs). Any issues with the trailer 'driving the bus' when some buses have considerable overhang past the rear wheels of the bus? I see shorties with very little overhang but I might like the extra space of a half bus which does have some considerable amount of overhang. Any advice is appreciated!
02-18-2016, 12:03 PM
Coachwork: Startrans
Engine: 5.4 litre
Rated Cap: 12
I opted for a shuttle bus. I haul my car trailer often with utv,atv. And many times with a car or truck on the trailer. Plus I think it looks better than a skoolie, almost RV looking.
02-18-2016, 01:19 PM
if you were flat towing a car, the overhang might be a problem dragging the front end of the car as you turn. with a trailer, that should be no problem.
buses are wider, you might like a longer neck on the trailer... a bit longer than half the width of the bus.
02-18-2016, 05:58 PM
Chassis: thomas
Engine: 8.3 cummins
Rated Cap: 11 window
not trying to highjack op's post. i plan on flat towing a 98 chevy lwb truck from IL to VA, i bought a tow bar and im in the process of fabricating a hitch. whats the best set up. i have a 10' tail.
02-18-2016, 07:24 PM
Engine: 466DT
My bus has my car trailer behind it 95% of the time. If it didn't have the beaver tail on the trailer, I would say there is never an issue. As it is now, it drags quite a bit into alot of entrances a such. More annoying then anything.
20150706_191309 by Hvbuzz, on Flickr
I was bored this winter so I am in the process of building a dedicated trailer for the bus, just to haul my jeeps around. I was going to post it up later in my bus build. But here is a sneak peek.
20160215_132244 by Hvbuzz, on Flickr
20160130_124934 by Hvbuzz, on Flickr
No more tail dragging. I also made the tongue longer, so now I can jack knife the trailer behind the bus. For when I get into those tights spots.
02-18-2016, 08:47 PM
Year: 1975
Chassis: Gillig
Very nice!
Your shop is CLEAN!!
02-19-2016, 08:57 AM
Engine: 5.4 litre
Rated Cap: 12
Didn't I see this on pirate maybe?..
02-19-2016, 09:45 AM
Moderator
Engine: DT408, AT545
Rated Cap: 23 500 gvw
Them's fighting words!
02-19-2016, 09:52 AM
Moderator
Do I spy 19.5 wheels on the trailer?
02-19-2016, 09:54 AM
Engine: 5.4 litre
Rated Cap: 12
Right...lol.. I know this ain't the forum for those words. Just my opinion.
02-19-2016, 10:11 AM
Engine: 466DT
Originally Posted by Alan N
Very nice!
Thanks!
If you see pictures from the other side of the garage, it's a mess.
02-19-2016, 10:13 AM
Engine: 466DT
Yep, it's on there.
02-19-2016, 10:16 AM
Engine: 466DT
Good eye!!
02-19-2016, 10:24 AM
Moderator
Good eye!!
Certain things you see on a trailer tell you that someone ain't messin' around. That's one of them.
