Old 04-28-2011, 05:53 AM   #1
Coachwork: BLUE BIRD
Chassis: I H CONVENTIONAL
OVERHEAD WARNING LIGHTS
I HAVE SEEN SOME CONVERSIONS WITH CLEAR LENSES, HAS ANYONE WIRED THESE LIGHTS AS FLOOD LIGHTS? WHERE HAVE YOU OBTAINED THE CLEAR LENSES? THANK-YOU
SCARECROW is offline   Reply With Quote
Old 04-28-2011, 01:16 PM   #2
lornaschinske's Avatar
Rated Cap: 89
Re: OVERHEAD WARNING LIGHTS
I know that http://www.tacbusparts.com/ has them. Other bus parts places should as well. I need to get 4 clear covers for ours (We will change the outer front to turn/running lights and outer lights on the the rear will be stop/brake/turn... both will be using new light bulbs like what is in the standard lights).
Fulltime since 2006
Old 04-29-2011, 12:20 AM   #3
Engine: DTA360
Rated Cap: 16
I got mine from http://www.schoolbuspartsco.com/...
Part number - WEL1003-3
dirtygoat is offline   Reply With Quote
Old 05-17-2011, 11:25 AM   #4
Engine: 5.9 Cummings
Rated Cap: 24
it sounds like a great idea but doesn't the light beam just shine straight ahead and not angled to the ground where a person would want it to shine?
funbus63 is offline   Reply With Quote
Old 05-17-2011, 04:11 PM   #5
Stuff's Avatar
they are not ment to be headlights. think like the round light on the side of some rv's
Old 08-01-2011, 11:22 AM   #6
Hope you are refering to Fog lights. powerful fog lamps will be ideal for this.
Arnoldra is offline   Reply With Quote
Old 12-09-2011, 07:22 PM   #7
freakn's Avatar
In BC it is illegal to have any forward pointing white light above 47" from the ground while on the road. I would suspect most of North America has similar rules
Living the dream in the Kootenays
freakn is offline   Reply With Quote
Old 12-11-2011, 03:35 PM   #8
somewhereinusa's Avatar
Chassis: AARE
Engine: 3116 Cat 250hp
Presumably they are legal, otherwise whoever built the bus wouldn't have done it.
I wouldn't be too sure about that. I once got a ticket on a three year old semi trailer for a "missing" light. Now, I
have no idea whether the officer or the manufacturer was right, didn't bother to look up the law, just paid the ticket.
The officer said I needed some lights on the front of the trailer, visible from the front. It doesn't matter that you can't see
the front of the trailer from the front when hooked to a tractor. Maybe he was just lonely, it was 2AM in St George,UT, he probably
hadn't seen anyone through his scale in a few hours.
I've found that it doesn't really matter what the law actually says, the rule is whatever the officer says it is. For the most part, they know
that someone from 2000 miles away is generally just going to pay the harassment tickets.
I've also seen lots of things on RV's that aren't legal.
Old 12-11-2011, 04:16 PM   #9
wtd
wtd's Avatar
Year: 1982
Coachwork: Thomas TransitLiner
Originally Posted by Iceni John
More about using the old red rear flashers as extra brake lights:
I was behind a newer-model bus (maybe a MCI?) on the freeway last night, and it had extra brake lights almost at roof height. There was one at each side, so they weren't on the centerline as FMVSS 108 specifies. Presumably they are legal, otherwise whoever built the bus wouldn't have done it. These lights were clearly visible when the lower regular brake lights were obscured by other vehicles behind it.
Seems there's only a minimum height requirement/restriction for stop lights.
California Vehicle Code
Section 24603 - Stoplamps
(g) Any vehicle may be equipped with supplemental stoplamps mounted to the rear of the rearmost portion of the driver's seat in its rearmost position in addition to the lamps required to be mounted on the rear of the vehicle. Supplemental stoplamps installed after January 1, 1979, shall be red in color and mounted not lower than 15 inches above the roadway. The supplemental stoplamp on that side of a vehicle toward which a turn will be made may flash as part of the supplemental turn signal lamp.
Entire 'Stoplamps' section is here -> http://www.dmv.ca.gov/pubs/vctop/d12/vc24603.htm
There is both a minimum and maximum height on the fog lamps tho' -
Section 24602 - Fog Taillamps
(2) The lamps shall be mounted not lower than 12 inches nor higher than 60 inches.
Entire 'Fog Taillamps' section here -> http://www.dmv.ca.gov/pubs/vctop/d12/vc24602.htm
Originally Posted by somewhereinusa
I've found that it doesn't really matter what the law actually says, the rule is whatever the officer says it is. For the most part, they know that someone from 2000 miles away is generally just going to pay the harassment tickets.
Ain't that the truth ...
Tom
The Rolling Motel Room
Where DIY meets WTF
wtd is offline   Reply With Quote
Old 12-12-2011, 04:04 PM   #10
Year: 89
Coachwork: thomas
Engine: 7.3 diesel
I hooked my overhead lights to be spot lights. They are 75w bulbs each. Hooked them up in sets of 2, great if you need a little more light at night. At Talladega they were great when a generator went down. All 8 work on at one time really lights up the area....Just cant have them on while driving. But if no ones around I turn them on just to see how it looks going down the road
see my conversion at https://www.skoolie.net/gallery/v/Skoolies/Putters+Bus/
putterspitt is offline   Reply With Quote
Old 12-12-2011, 05:23 PM   #11
I got some clear lens that came with the ealed beams, 4 for front and 4 for the rear. I have the clear ones on the front but Im not sure if I like the look, they are just to light up the front, havent done the back yet, I might end up taking them off and covering in the holes, I find the lens still give it school bus look. im going to think more about it over the winter
overhead bulkhead compartment ideas wanted John Brothers Conversion General Discussions 16 08-19-2014 07:12 PM
overhead bulkhead compartment ideas wanted John Brothers Conversion General Discussions 3 06-27-2014 07:10 AM
Running Lights and tail lights not working bapos Alternative Fuels | Electric, Propane, Wood & Biofuels 2 12-14-2011 11:32 AM
Tail lights,running lights not working putterspitt Conversion General Discussions 2 10-12-2010 05:19 PM
Re-Installing Warning lights.... TygerCub Conversion General Discussions 1 09-19-2009 12:25 PM
