Old 10-01-2012, 11:22 PM   #1
crazycal's Avatar
Paint for bus.
I was at Home Depot looking at paint. I asked the paint guy about coloring the Rustoleum. He said it couldn't be done, but I could use the Behr paint. If I used the oil based primer, he said it would be durable. Can this be so? House paint will hold up on the bus?
I'm hungry!
You Gotta Let Me Fly
Old 10-01-2012, 11:47 PM   #2
Stuff's Avatar
Coachwork: Goshen
Engine: 7.3
Rated Cap: 25
Re: Paint for bus.
well oil based pretty much soaks into anything. had some vandals use some on statues around here once. took lots of time and money and equipment to get it off.
Old 10-02-2012, 12:39 AM   #3
crazycal's Avatar
Re: Paint for bus.
The primer is oil based. The paint is water based latex. My knowledge is very limited when it comes to paint.
I'm hungry!
Old 10-02-2012, 06:24 AM   #4
Accordion's Avatar
Year: 1973
Engine: CAT 1160 V-8 Diesel
Re: Paint for bus.
I painted my 1966 camper twice. I used enamel oil based house paint.
First, I thoroughly cleaned it with TSP. Back then you could get real TSP (tri sodium phosphate). It was fairly caustic. You had to wear rubber gloves. Now they have what is called TSP substitute.
After the surfaces were cleaned, I combined one quart of Penetrol to one gallon of paint. Penetrol is basically linseed oil.
I used a brush and a roller to apply the paint. It was a durable and shiny paint job that lasted years.
After the paint dried for a week, you could even wax the vehicle with car wax.
Old 10-02-2012, 03:21 PM   #5
lornaschinske's Avatar
Rated Cap: 89
Re: Paint for bus.
We used ACE Hardware's "RUST STOP". It can be custom tinted. Similar properties as Rustoleum. I used a foam roller. Didn't thin it at all. Also used it as the 1st coat on faux finishing the metal ceiling inside the bus.
Body: ACE Rust Stop Turquoise Bay A37-4
Rub Rails: Rustoleum Hammered Copper & Rustoleum Hammered Black
Bumpers: Rustoleum Hammered Black
We painted the Class C with a paint brush and regular latex house paint (semi gloss trim). Had to use an aluminum primer under the paint. Did that back in 2007(?) and it still looks good. The bus is steel.
Fulltime since 2006
Old 10-02-2012, 10:00 PM   #6
opus's Avatar
Chassis: All-American R/E
Re: Paint for bus.
I did mine, didnt prep anything, just brushed it on. Thinned it a little because it was in the upper 40's. low 50's. Hold on real well. Its been a year and a half I think now. Ace Rust Stop.
Old 10-15-2012, 03:39 AM   #7
Coachwork: midbus
Chassis: chevy
Rated Cap: 29
Re: Paint for bus.
what i used was a garage floor epoxy paint from home depot to paint my bus. its only about $22 gallon around here. i only needed 2 gallons, one white, one black, to paint my bus (short bus) all i did was wash it with a good dish soap using bundles of steel wool instead of a sponge to remove all waxes, tar, etc. then after it dried i just used a roller to apply. it took 3 coats, and take your time! the finish is great. exactly what i wanted. i used a cloth roller because i wanted a "textured" finish, but i used a foam roller on the whole roof and it worked great, nice, smooth, and shiny. they will color the garage epoxies any color you want also. i kept the roof paint a bright white, but the rest i went with a kind of semi-gloss charcoal black. with this too, it creates a nice a hardened finish for the paint. we used to paint the equipment and trailers for our fire department with it as well. hope this helps!
hordechick is offline   Reply With Quote
Old 10-15-2012, 09:34 AM   #8
syke's Avatar
Chassis: All American RE
Re: Paint for bus.
Like lorna and opus we went with the ace rust stop paint. Custom tinted and rolled it on. It's been about 6 months. So far so good.
Ryan
Bluebird All American RE: Great White Buffalo (gone but not forgotten)
Our build thread: viewtopic.php?f=9&t=10065
syke is offline   Reply With Quote
Old 10-24-2012, 02:41 PM   #9
Re: Paint for bus.
Yes, you can use a latex paint on top of an oil primer, but not the other way around. I'd pick up a spray gun, too, if you don't have one. You can get a pretty good one from Harbor Freight for ~$25, and it'll make your life a hell of a lot easier, as well as your coat both prettier, and stronger.
icnivad is offline   Reply With Quote
Paint for Bus jkindt Conversion General Discussions 2 05-03-2010 12:55 PM
Paint...and more paint...and more paint... skooliedave Conversion General Discussions 13 02-02-2008 03:22 PM
What paint to use? KC10Chief Conversion General Discussions 7 02-05-2007 04:38 PM
When to paint andybus9 Conversion Tutorials and How-to's 16 11-30-2005 08:24 PM
Paint Job Done!!! dammitAndy Conversion General Discussions 17 06-29-2005 07:02 AM
