Old 10-22-2018, 01:53 PM   #1
tugboater's Avatar
Chassis: Saf T Liner MVP 11 window 32í
Engine: CAT 3126E
paint interior ceiling & walls before foam?
We're about to insulate with spray foam. I'm hesitating for a moment in hopes of an experienced thought or two. Is it worth a coat of paint on the walls and ceiling prior to foam? Seems like it couldn't hurt & may help seal and add a bit of insulation & extra vapor barrier. I've noticed some converters have done it, others have not.
Our bus is well sealed as it came. No rust or leaks from the ceiling. Is it overkill? I'm leaning toward doing it.
thx
One...slow...step...at a time.
tugboater is offline   Reply With Quote
Old 10-23-2018, 06:46 PM   #2
mikeypj's Avatar
Engine: 9.L
Rated Cap: 64
Im painting mine before i insulate, im not going with spray insulation. if thats what you think you need to do, then do it!
mikeypj is offline   Reply With Quote
Old 10-23-2018, 07:37 PM   #3
Ronnie's Avatar
Engine: 345 international V-8
Is the metal bare? If so would be inclined to paint it first
Old 10-24-2018, 09:37 PM   #4
david.dgeorge07's Avatar
Chassis: Thomas
Engine: CAT 3126
The shop I used said it didnít matter. Foam would make airtight bond. Might want corroboration, but thatís what they said.
My Build Thread:
http://www.skoolie.net/forums/f11/4-...ner-18205.html
