Old 07-20-2010, 08:20 PM   #1
opus's Avatar
Chassis: All-American R/E
Paint prep
How about a light sandblasting instead of sanding? Sure would be easier and quicker.
Anyone ever try it?
Old 07-20-2010, 09:27 PM   #2
Year: 55
Coachwork: Ford
Re: Paint prep
Opus,
Give a little more information about the current condition of your rig. Is it painted, rusty, bare metal and you want to repaint it? Sandblasting will take it down to bare metal, and be very careful in sandblasting large flat areas - it will warp it. If you are thinking you can lightly blast it, just enough to rough up the paint - the texture of the blasted paint will show through the new paint like you wouldn't believe.
Sandblasting is a messy time-consuming job, I farm it out as often as I can.
bodaver32 is offline   Reply With Quote
Old 07-20-2010, 09:38 PM   #3
opus's Avatar
Re: Paint prep
Its nicely painted school bus yellow. I am going to repaint it. I thought using a very fine sand would be a better option than sanding....ugh. I was just wanting to scuff it up, as I would in sanding. I will probably end up rolling the paint on. Seems to be the way everyone else does it.
Old 07-20-2010, 10:07 PM   #4
Year: 55
Coachwork: Ford
Re: Paint prep
I would get either an electric or air DA sander and go over the entire bus. You would be amazed how fast it will go. Much faster than blasting or anything else. An air DA requires a large air compressor to operate - so electric may be your best bet. You are not sanding to get down to the metal, just to get the shine off the old paint and give the new paint something to stick to.
I sprayed mine, but I was after a different look.....
Old 07-20-2010, 10:29 PM   #5
opus's Avatar
Re: Paint prep
I too was thinking a DA, I have enough air. I was wondering about rub rails and all those odd things, hence the sand blasting thought.
Nice looking ride, '57?
Old 07-21-2010, 08:04 AM   #6
Year: 55
Coachwork: Ford
Re: Paint prep
It is a 1955 Ford.
The interior work is ongoing and slow. I have a posting of it in the conversions section, but I haven't updated it in a while. I need to do that and get everyone caught up.
Old 07-21-2010, 09:58 AM   #7
opus's Avatar
Re: Paint prep
What grit would you suggest?
i have painted 5 buses, and i prefer to use an electric palm sander. Should only take an hour or so to do the entire bus. Like someone else stated. You do not need to get down to bare metal, all you want to do is make the old paint dull (not shiny) Then i wipe the entire surface down using paper towels and mineral spirits. none of that save the earth imitation paint thinner crap, but actual mineral spirits. Then wipe it down again. This removes all of the paint dust you just created with the sander. I also like to wear latex surgical gloves when i am dealing with paint. Makes cleaning my hands a lot easier!
I don't remember what grit i use....somewhere around 180 or 220 i suppose.
Old 07-21-2010, 03:33 PM   #8
Year: 55
Coachwork: Ford
Re: Paint prep
I normally start with 220 to cut through the old paint then do a bit finer to get rid of some scratches.
Old 07-21-2010, 03:36 PM   #9
Scratchy's Avatar
Engine: 5.9 Cummings
Re: Paint prep
I used Scotch brite pads and elbow greese on the ribs and areas where I couldn't get my DA into. Again just trying to remove the shine for the new paint to stick.
Good Luck.
Scratchy is offline   Reply With Quote
Old 07-21-2010, 03:45 PM   #10
opus's Avatar
Re: Paint prep
Very helpful, thanks.
(Spray) Paint Job. Pre/Post prep. bassbus Conversion Tutorials and How-to's 14 Yesterday 03:11 PM
Harsh winter prep for full-time RVing? tomas_maly Conversion General Discussions 5 06-17-2016 06:51 PM
Floor prep? Bureau602 Conversion Tutorials and How-to's 5 07-30-2014 10:10 PM
jasco Prep and Primer MissJaneStrummor Short-Bus Conversion Projects 12 02-21-2014 07:33 AM
What paint to use? KC10Chief Conversion General Discussions 7 02-05-2007 04:38 PM
